Wireless
8318 Discussions
I have windows 7 prof edition and driver ultimate-N 6300 AGN 14.2.0.10 installed. Tried to install newer version 18.40.4 but this upgrade is not supported. Please uninstall manually. control panel-software does not give the option to uninstall just chang
GPrzy
I have windows 7 prof edition and above driver 14.2.0.10 installed. Tried to install newer version 18.40.4 but this upgrade is not supported. Please uninstall manually. control panel-software does not give the option to uninstall just change.
installed driver utility that upgraded network adapters, but above driver is still same version.
in device driver selected uninstall - but installer of 18.40.4 still indicates older version should be removed..
Is there a possibility to remove this driver for upgrade or how to proceed with upgrade.
thanks for all update/help
Best Regards, Guy Przytula
ASouz7
guy_przytula,
The Intel® Centrino® Ultimate-N 6300 is not on the list of the Intel® Wireless Adapters that support the Intel® PROSet/Wireless Software version 18.40.4. You can confirm this piece of information by access this link: https://downloadcenter.intel.com/download/26094/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-7- Intel® PROSet/Wireless Software and Drivers for Windows 7* - please scroll down almost all the way to the bottom in order to see the list of adapters that support this package version.
Currently, the driver version available for this adapter on Windows*7 is version: 18.12.1 and can be found through this link: https://downloadcenter.intel.com/download/25223/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-7-?product=59474 Intel® Centrino® Ultimate-N 6300 - Driver version: 18.12.1
Intel always recommend to obtain the latest drivers from the computer manufacturer first as they may contain all the necessary adaptation to the type of system you have in order to guarantee all of its functionalities. For your convenience, here a link: http://www.intel.com/content/www/us/en/support/topics/OEMs.html Computer Manufacturer Support Websites where you may find the contact information for your computer manufacturer:
Aleki
guy_przytula,
We haven't heard from you in a while so we would like to know if the information provided helped you kill your doubts about this adapter. Please, let us know if there is anything else we can do to assist you.
Aleki
