Wireless
8310 Discussions
I need a wifi/Bluetooth internal card for my Lenovo M720e sff BD and no one can help me 11BD504100
DMcke9
AlHill
This is where you must consult with Lenovo for compatibility.
Doc
n_scott_pearson
According to what I can see, you do not have a M.2 expansion slot for wireless. You will need a low-profile PCIe x1 card.
The best on the market right now is a card outfitted with the Intel AX200 module. This gives you Wireless-AX, WiFi 6 and Bluetooth 5 support. While you may not be able to use all of these features immediately, you will have at least future-proofed yourself. Here is an example of such a card: https://www.amazon.com/EDUP-3000Mbps-802-11AX-Bluetooth-Wireless/dp/B084P8KHMH.
Hope this helps,
n_scott_pearson
I should point out that I am sitting at a PC that is outfitted with one of these cards. I particularly like this implementation because it provides the additional cooling for the module. It is possible to separately purchase the AX200 M.2 module and a card carrier/adapter and save a few dollars, but it just isn't worth it.
