Wireless
8782 Discussions
I was trying to configure Intel® Dual Band Wireless-AC 8265 in 5ghz mode on a Dell Laptop. I am getting an error like channels configured are not supported in the driver. Does anyone have any idea regarding this ??
APrak7
Wanner_G_Intel
Hello APrak7,
Thank you for posting on this Intel Community.
For optimal connectivity, we recommend using the Recommended Settings for 802.11ac Connectivity.
If using 2.4 GHz band, use only channels 1, 6, or 11. If using the 5 GHz band, use channels 36, 40, 44, or 48. Keep in mind that some access points or wireless routers try to automatically select the best channel to use.
Make sure you are connecting to a 5 GHz network. Depending on the network connection and configuration, SSIDs (name of the network) are named differently to choose what frequency is the best.
Also, make sure you are running the latest Original Equipment Manufacturer (OEM) driver and operating system build.
Wanner G.
A Contingent Worker at Intel
Wanner_G_Intel
Hello APrak7,
Were you able to follow the recommendations provided?
If you need further assistance, please let us know.
Wanner G.
APrak7
I have used the IWLWIFI driver from the LinuxCore30 release, along with firmware version 36 for Intel® Dual Band Wireless-AC 8265. In access point mode, It works perfectly
on 2.4 GHz band and 20/40MHz channels but not supporting 5GHz band.
Although in Client mode it works perfectly in both the mode i.e 2.4 and 5 GHz.
Wanner_G_Intel
Hello APrak7,
Is this a problem you are encountering in a Linux environment only?
For general questions about Intel Wi-Fi on Linux, email linuxwifi@intel.com.
To report a bug or issue, follow the guidance on the bugs and support page.
For more information, these support sites may help you further:
Linux* Drivers
Firmware git tree
Wanner G.
APrak7
I have tried only on Linux environment. I have mailed the issue to linuxwifi@intel.com.
Wanner_G_Intel
Hello APrak7,
Thank you for the update.
We will close this inquiry. If you need further assistance, please post a new question.
Wanner G.
