No matter what i do, the wifi driver is FAILED TO START
it says THIS DEVIDE CANNOT START (code 10)
{Operation Failed}
The requested operation was unseccssful.
i uninstalled it, reinstalled it, nothing. same same. windows is updated. WIFI adapter not working at all. no idea what to do. i even tried windows system restore (it is failing)
Hello Charbel619,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Is this a laptop or desktop computer?
4. Is this issue recent? If so, when did it start?
Deivid A.
Hello Charbel619,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
Hello Charbel619,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
I have a similar problem, exact same error. This occurred in conjunction with running the Windows 11 Update. I have since restored back to Windows 10. Still an issue. Tried to submit the report referenced above via the tool and I get a "This site can't be reached" error.
Original adapter, laptop computer, started when I tried to log on this morning. Now on a wired connection temporarily.
