Wireless
7102 Discussions
INTEL WIFI ADAPTER AX201 UNII-1,UNII-2 ISSUED
AlFarez
Hi, Im based in Indonesia, as far as i know, the UNII-1 and UNII-2 channel in indonesia  has been permitted by KOMINFO, but i dont see any channel when i analyze thats channel
Is possible unlock channel UNII-1 and UNII-2 in Indonesia with my existing adapter? thank you for any replies
Jean_Intel
Hello AlFarez,
As each country may have different regulatory requirements, before you install/change the Intel® Wireless Adapter in a system, you must contact the system manufacturer to determine if your system is capable of running UNII-1 and UNII-2 channels. However, it is important to mention that even if the channels are now approved, it does not indicate that it is ready for use, you should contact your system manufacturer for further information
Jean O.
3Fees
From what I see UNII is Unlicensed National Information Infrastructure. I dont think Intel adapters support unlicensed broadcasts channels or bands-they stay within licensed broadcasting bands, some of these UNII Bands can overlap and interfere with Radar avoidance Bands and  Government weather radar bands. These UNII bands are for radio operators that have control of the wattage receive/sent and are restricted. In other words the bands you see thru the WiFi router's web interface where the WiFi adapter is setup is what you can use. The fines for using these UNII channels or bands if they interfere with government broadcasts would be huge and they will confiscate the equipment with the modern triangulation equipment governments have they could pinpoint where the illegal broadcast is coming from and sent some very unfriendly people to rectify the situation.
Cheers
3Fees
AlFarez
alright then, thank you sir
Jean_Intel
Hello AlFarez,
Jean O.
Jean_Intel
Hello AlFarez,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello AlFarez,
I am glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, I will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
