5GHZ is not working on latest driver which date is 3/25/2022. Please fix the issue. In older version it works perfectly.
Hello shimulx,
To have a better understanding of your issue, please provide me with the following:
- What is the driver version you installed that presents the issues?
- What installation process did you follow?
- Is this a laptop or desktop system?
- Is this issue happening at the home, office environment, or both?
- Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
Jean O.
Version is 22.130.0.5 and released on 3/25/2022. My system is desktop and motherboard is ASUS PRIME-H510M-A-WIFI. In this motherboard wifi adapter is pre-installed. Thank you.
I restarted my pc and version 22.130.0.5 started to work! If any problem occurs then I will post here. Thank you!
Hello shimulx,
I am glad to know you found a solution. Thank you for taking the time to share it; hopefully, it may help other community members experiencing similar behavior.
I will keep this thread open. If you face any other issues, do not hesitate to let me know.
Jean O.
Sorry ! 5GHZ is creating problem again !!! Now I am using microsoft driver and finally no problem at all....
Hello shimulx,
I am sorry to hear that the issue persists.
You mentioned that the issue disappeared after using the Microsoft driver; I would like to confirm what is the driver you are running at the time.
Also, I would like to confirm some information to have more insight into your issue:
Jean O.
I already answered this question before, Please check.
Hello shimulx,
Thanks for the heads up. I confirmed that you have already provided the information I requested. My apologies for being repetitive. Yet, there is still some information that was not.
I want to confirm the driver installation process you followed to install driver 22.130.0.5.
Also, let me know which is the new driver you installed on your system. You refer to it as Microsoft Driver.
Create a report using the Intel
- Download the Intel SSU (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html)
- Open the application and click on "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click on "Next"; then "Save."
Jean O.
Hello shimulx,
I hope you are doing fine.
Jean O.
No, Now I am using microsoft driver and everything works great. Latest Intel Driver is creating issues.
Hello shimulx,
I would like to confirm some information. It would help me have a much better comprehension of your issue. Let me know the following:
- Have you tried connecting your device to another 5GHz network?
- Can other devices connect to the 5GHz network?
- What driver installation process did you follow to install driver 22.130.0.5?
- Let me know which is the new driver you installed on your system. The one you refer to as Microsoft Driver.
- Create a report using the Intel System Support Utility (Intel SSU). It will provide us with vital information for further support:
- Download the Intel SSU (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-window...)
- Open the application and click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
Jean O.
Hello shimulx,
Jean O.
Hello shimulx,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
