I have a 8260 in a Dell 7710 Brand new. When I try to connect to iPhone as a hotspot connects for 2 seconds then drops connection. I have driver 19.20 installed 64 bit
Hello rs7921,
It's important to note that the drivers provided in our download center are generic versions. Our recommendation is that whenever possible, to use the version provided by your OEM. This is the only version that takes into account changes and customizations made when the adapter was integrated into your system.
http://www.dell.com/support/home/us/en/04/product-support/product/precision-m7710-workstation/driver... Drivers and Downloads for the Dell® Precision® 7710
Note: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel®.
In order to better assist you, we would like to know the following:
- What operating system are you using?
- Are you able to connect to other networks?
- Do other computers have the same problem connecting to your hotspot?
- Do you receive any error messages, or does the network simply disconnect?
We look forward to hearing back from you.
Carlos A.
I used the Dell driver first when thatdisnt work i upgraded to latest driver from your website
rs7921,
Please remember that wireless passwords are case sensitive. You can try changing the wireless password for your hotspot, and then try to connect again.
However, in order to provide a more accurate response we would like to have the following information:
Carlos A.
Windows 7 Pro 64 bit
Yes I can connect to other networks on wifi
I have connected iPhone successfully with 2 other laptops a Dell m6800 and an Alienware laptop with no issues
no error messages
rs7921,
It's possible that an error may have occurred when creating the wireless profile for your hotspot. We can delete this profile (make your computer forget this network), and then connect again.
1. Open Command Prompt as administrator.
2. Type: netsh wlan delete profile name=*
3. Close Command Prompt, connect to your hotspot again.
If this doesn't work, you may need to perform a clean installation of your wireless drivers. You will lose wireless connectivity while doing this, so it's important to download and save the wireless driver to an easy to find location before beginning this troubleshooting.
We recommend using the latest drivers provided by your computer manufacturer:
http://www.dell.com/support/home/us/en/04/Drivers/DriversDetails?driverId=4Y1DP http://www.dell.com/support/home/us/en/04/Drivers/DriversDetails?driverId=4Y1DP
Alternatively, you may use our latest generic drivers:
https://downloadcenter.intel.com/download/26344 https://downloadcenter.intel.com/download/26344
1. Remove WiFi components
a. Uninstall driver from Device Manager. If prompted, choose remove driver.
b. Remove Intel® PROSet/Wireless Software and Drivers from Programs and Features in the Control Panel.
2. Remove temporary files
a. Press Windows* Key + R to open the run box. Type Cleanmgr.exe. Press OK.
b. Select the main drive, usually C:\.
c. Check Temporary Files and uncheck everything else. Press OK.
3. Remove hidden folders
a. Go to %UserProfile%\AppData\Roaming\ (you can type this in the run box)
b. Delete the Intel® folder.
4. Download and install your chosen version of the Intel® PROSet Wireless Software and Drivers.
a. Choose to http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005564.html Customize.
b. Select all options available.
5. Connect to your Hotspot.
Please let us know if this helps.
Carlos A.
Dell got wifi adapter to connect and stay connected after 4 hours thanks for your help
rs7921,
We're glad to hear your issue has been resolved. Your computer manufacturer is always a great resource for support, specially on new devices.
If there is anything else we may help you with, just let us know.
Carlos A.
