Community
cancel
Showing results for
Search instead for
Did you mean:
Intel 9560NGW PCIe connection
Jump to solution
my question is regarding INTEL 9560NGW Wireless module. I am trying to test this module on mini ITx board with intel core i3. I am using Fujitsu D3436-S adapter for connection of wifi module to mini PCIe slot on ITx board. But after power up, wifi module is not recognized by OS and I cannot see it in Device Manager also. I think that this might be a HW issue, as I tried it on several ITx boards with same result. Should I use different adapter? Can you recommend solution?
Thank you
ftp://ftp.ts.fujitsu.com/pub/Mainboard-OEM-Sales/Products/Accessories/LAN_&_WLAN/DS_D3436-S_mPCIe_to...
Accepted Solutions
You should try the Intel 9260NGW, since the 9461, 9462, and 9560, all use the CNVio Protocol, which is as of now, only supported by the Pentium Silver and (maybe) the Pentium Gold series.
Protocol usage aside, the 9260 is equal to the 9560.
Thank you for recommendation.
