I have Intel AC-9260 and Ubuntu 20.04. Kernel: 5.13.0-37-generic.
I sometimes see available wifi with very low signal.
If i try to connect, it doesn't connect 99% of the time. And 1% of the time it connects and provides very low speed internet. And disconnects after sometime.
Things I tried:
1- options iwlwifi 11n_disable=8 and 1 swcrypto=1 bt_coex_active=0
2- Downloading latest 9260 firmware from intel website and putting it in /lib/firmware
But no success.
Please help me fix this.
Tell me if you need any other info from my side.
Hello nikhilchhabra,
In order to better assist you, please provide the following information:
- Did you download the firmware from this website directly? (https://www.intel.com/content/www/us/en/support/articles/000005511/wireless.html) Or did you look for the latest firmware version available for the kernel in https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/
- Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
- Was the wireless card working fine at some point before?
As well, please run a report with the Intel® System Support Utility for Linux (https://www.intel.com/content/www/us/en/download/18895/26735/intel-system-support-utility-for-the-li...?) and attach the file to your reply.
Steven G.
Solved:
The antenna was missing.
We are glad to know you found a solution. Since the thread is now solved, we will proceed to close it.
If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
