Wireless
8653 Discussions
Intel AX101 WRDD/DFS issues on Debian 13 Trixie
RicoBelo
I have a chinese Mini-PC with an Intel N150 CPU and a soldered Intel AX101 wireless card running Linux Debian 13 (Trixie)
want to use the wireless card as an AP, which is supported by AX101 chip and driver, in 802.11ax mode on the 5GHz band.
As I live in France, I forced cfg80211 module to load WRDD for France with the kernel parameter
cfg80211.ieee80211_regdom=FR
The global registration is then correctly globally set to FR, but the wireless card is kept unconfigured with no country and no DFS information:
# iw reg get
global
country FR: DFS-ETSI
	(2400 - 2483 @ 40), (N/A, 20), (N/A)
	(5150 - 5250 @ 80), (N/A, 23), (N/A), NO-OUTDOOR, AUTO-BW
	(5250 - 5350 @ 80), (N/A, 20), (0 ms), NO-OUTDOOR, DFS, AUTO-BW
	(5470 - 5725 @ 160), (N/A, 26), (0 ms), DFS
	(5725 - 5875 @ 80), (N/A, 13), (N/A)
	(5945 - 6425 @ 320), (N/A, 23), (N/A), NO-OUTDOOR
	(57000 - 71000 @ 2160), (N/A, 40), (N/A)
phy#0 (self-managed)
country 00: DFS-UNSET
	(2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
	(2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
	(2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
	(5170 - 5190 @ 80), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5190 - 5210 @ 80), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5210 - 5230 @ 80), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5230 - 5250 @ 80), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5250 - 5270 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5270 - 5290 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5290 - 5310 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5310 - 5330 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5490 - 5510 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5510 - 5530 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5530 - 5550 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5550 - 5570 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5570 - 5590 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5590 - 5610 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5610 - 5630 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5630 - 5650 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5710 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5735 - 5755 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5755 - 5775 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5775 - 5795 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5795 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
	(5815 - 5835 @ 20), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-HT40PLUS, NO-80MHZ, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
At least I can see many channels in the 5GHz band available for DFS. So I try a minimalistic hostapd.conf file to start an AP centered on channel 100 with 802.11ax, but it fail : hostapd enumerates all channels in the 5GHz band with "No IR" flag :
nl80211: 2402-2437 @ 40 MHz 22 mBm
nl80211: 2422-2462 @ 40 MHz 22 mBm
nl80211: 2447-2482 @ 40 MHz 22 mBm
nl80211: 5170-5190 @ 80 MHz 22 mBm (no outdoor) (no IR)
nl80211: 5190-5210 @ 80 MHz 22 mBm (no outdoor) (no IR)
nl80211: 5210-5230 @ 80 MHz 22 mBm (no outdoor) (no IR)
nl80211: 5230-5250 @ 80 MHz 22 mBm (no outdoor) (no IR)
nl80211: 5250-5270 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5270-5290 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5290-5310 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5310-5330 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5490-5510 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5510-5530 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5530-5550 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5550-5570 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5570-5590 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5590-5610 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5610-5630 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5630-5650 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5650-5670 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5670-5690 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5690-5710 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5710-5730 @ 80 MHz 22 mBm (DFS) (no IR)
nl80211: 5735-5755 @ 80 MHz 22 mBm (no IR)
nl80211: 5755-5775 @ 80 MHz 22 mBm (no IR)
nl80211: 5775-5795 @ 80 MHz 22 mBm (no IR)
nl80211: 5795-5815 @ 80 MHz 22 mBm (no IR)
nl80211: 5815-5835 @ 20 MHz 22 mBm (no IR)
nl80211: Added 802.11b mode based on 802.11g information
nl80211: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484[DISABLED]
nl80211: Mode IEEE 802.11a: 5180[NO_IR] 5200[NO_IR] 5220[NO_IR] 5240[NO_IR] 5260[NO_IR][RADAR] 5280[NO_IR][RADAR] 5300[NO_IR][RADAR] 5320[NO_IR][RADAR] 5340[DISABLED] 5360[DISABLED] 5380[DISABLED] 5400[DISABLED] 5420[DISABLED]
nl80211: Mode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484[DISABLED]
Frequency 5500 (primary) not allowed for AP mode, flags: 0x15b NO-IR RADAR
Primary frequency not allowed
wlo1: IEEE 802.11 Configured channel (100) or frequency (5500) (secondary_channel=0) not found from the channel list of the current mode (2) IEEE 802.11a
wlo1: IEEE 802.11 Hardware does not support configured channel
Could not select hw_mode and channel. (-3)
wlo1: interface state COUNTRY_UPDATE->DISABLED
wlo1: AP-DISABLED
 So I tried to enable DFS and force 80MHz band centering between channel 100 and 106 with a more elaborated hostapd config. Bu once again, hostapd fails to start because it fails to start DFS scan.
I was able to start hostapd in 802.11ax on the 2.4GHz band as there is no DFS gotchas on the band, but at the price of terrific bandwidth of less than 90Mbps.
I join my dmesg, config files, and iw outputs in attachements
So at this point I assume the firmware forbid me to use the card in AP mode on 5Ghz band because of DFS, I don't really understand how and why. So can you help me to fix this ?
JedG_Intel
Hello RicoBelo,
Thank you for posting on Intel Community Forum. I appreciate your effort for sharing as much information as you could. This will definitely help with the investigation moving forward.
To address the issue properly, kindly share the information below.
1. What is the make and model of your Mini-PC? If possible, kindly share the direct link to it.
2. Were you previously able to configure and use the wireless card according to your preferred settings?
3. What is the Kernel and firmware version?
Best regards
Jed G.
RicoBelo
Hello Jed, thanks for your support
1. I brought this mini-pc on a French second hand market website called "leboncoin.fr" which will obviously not your :D, but the miniPC is branded "SOAYAN N2" and I found references on Alibaba and also Amazon :
https://www.amazon.fr/SOAYAN-Lake-N150-Computer-Business-Heimkino/dp/B0DTF11ZFT
https://www.alibaba.com/product-detail/SOAYAN-2025-Factory-Direct-N2-Mini_1601390125662.html?spm=a2700.details-description.0.0.79eeM2XVM2XVqW
This is obviously a generic product sold to many distributors, and unfortunately I was not able to find the manufacturer or any support.
2. Initially I didn't used the wireless at all : I use this server to share and transcode media files with Jellyfin over Ethernet, thanks to it great CPU and IGP (the N1xx series are really great and green products !)
 But as I recently added a new FireTV 4K with a weak wireless connection because my "real AP" is too far, and the mini-pc is just next to the FireTV stick, I through bridging the wireless card would be an far more elegant option than adding another AP !
The FireTV 4K is the reason why I want 802.11ax over 5Ghz : I want to archieve at least 500Mbps bandwidth with low latency
3. You can find kernel and firmware details in dmesg.txt output. For reference :
# uname -a
Linux jellyfin 6.12.48+deb13-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.48-1 (2025-09-20) x86_64 GNU/Linux
# dmesg |grep -P 'iwl|80211'
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-6.12.48+deb13-amd64 root=/dev/mapper/vg_sys-root ro cfg80211.ieee80211_regdom=FR
[    0.021764] Kernel command line: BOOT_IMAGE=/vmlinuz-6.12.48+deb13-amd64 root=/dev/mapper/vg_sys-root ro cfg80211.ieee80211_regdom=FR
[    3.414369] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.510206] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    3.519644] iwlwifi 0000:00:14.3: Detected crf-id 0x501, cnv-id 0x80400 wfpm id 0x80000030
[    3.520291] iwlwifi 0000:00:14.3: PCI dev 54f0/0244, rev=0x370, rfid=0x10c000
[    3.520940] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX101
[    3.526646] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.42
[    3.527662] iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
[    3.528420] iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
[    3.529024] iwlwifi 0000:00:14.3: firmware: failed to load iwl-debug-yoyo.bin (-2)
[    3.529612] iwlwifi 0000:00:14.3: loaded firmware version 89.4d42c933.0 so-a0-hr-b0-89.ucode op_mode iwlmvm
[    4.058973] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
[    4.059024] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    4.059032] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[    4.059041] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x10
[    4.059802] iwlwifi 0000:00:14.3: Detected RF HR1 B3, rfid=0x10c000
[    4.060202] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[    4.101019] iwlwifi 0000:00:14.3: base HW address: 94:b6:09:42:1d:b9
[    4.150719] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
I also forced regulatory information database from upstream instead of Debian DB:
# update-alternatives --get-selections | grep regulatory
regulatory.db                  manual   /lib/firmware/regulatory.db-upstream
RicoBelo
Hello Jed,
1. This is a generic chinese mini-pc, branded as "SOAYAN N2 Mini PC N150". You can find it on AliBaba as well as Amazon :
https://french.alibaba.com/product-detail/SOAYAN-2025-Factory-Direct-N2-Mini-1601390125662.html
I search for an eventual official website but didn't found anything suitable to request any support from the manufacturer.
2. Not really : I usually prefers Ethernet connection when possible so wireless was disabled. The reason why I need to activate it as AP is this host is exclusively used for transcoding media content using Jellyfin, and I just added an Amazon FireTV 4K stick with a weak Wifi connection because my "real" AP is to far away, so as the Mini-PC is just next to the FireTV stick, I thought far more elegant bridging its connection as an AP than installing another "real" AP for just one device.
3. I think you already have these information on the dmesg.txt attached file. FYI:
# uname -a
# dmesg | grep -P '80211|iwl'
 So:
kernel is stock Debian 13 (kernel 6.12.48)
firmware blob is 89.4d42c933.0 so-a0-hr-b0-89.ucode
I also need to precise that I switched to upstream regulatory database instead the the stock Debian provided :
JedG_Intel
Hello RicoBelo,
Thank you for sharing all this information. I really appreciate that you shared a reference link to your Mini-PC. I'll investigate this matter internally and I'll get back in touch as soon as possible.
Best regards
Jed G.
RicoBelo
Thanks for your help, I really appreciate
Hope you'll be able to find a solution
Eric
JedG_Intel
Hello RicoBelo,
I'm getting back in touch to gain additional information that will help with our investigation. Please see below.
- Have you had the chance to contact the Place of Purchase about the issue?
- Please generate System Support Utility report - Help Guide for the Intel® System Support Utility
Best regards
Jed G.
RicoBelo
Hello Jed,
I downloaded ssu_3.0.0.2_tar.gz and ran it on my system. the log is in attachment.
Eric
JedG_Intel
Hello RicoBelo,
Thank you for providing the SSU report, I appreciate it. Can you please also confirm if you were able to contact the Place of Purchase already about this issue?
I hope to hear from you soon.
Best regards
Jed G.
RicoBelo
Hello Jed,
The short answer: no !
The long one: I contacted the manufacturer on alibaba marketplace explaining almost what I detailed here... and he sent me a ZIP file containing Windows wireless drivers
JedG_Intel
Hello RicoBelo,
Thanks for the added information. Could you please confirm whether the driver supplied by the manufacturer worked for you?
Best regards
Jed G.
RicoBelo
Hi Jed,
As said, they only provided *Windows* drivers, while I'm running Debian 13 !
How do you expect me to use Windows drivers on a Linux system ???
Eric
JedG_Intel
Hello RicoBelo,
I apologize for any confusion. I had assumed that you previously attempted to use the Windows Operating System, as the manufacturer provided you with Windows drivers. Nonetheless, I will continue investigating this matter and will reach out to you with an update as soon as possible.
Best regards
Jed G.
JedG_Intel
Hello RicoBelo,
I am reaching out to provide you with an update. To continue troubleshooting the issue, please download the latest Kernel version 6.17 from The Linux Kernel Archives. Additionally, ensure that you are using the most recent firmware available in the Firmware git tree.
If the issue persists after implementing these recommendations, kindly inform me so that we can proceed with further troubleshooting.
Best regards
Jed G.
JedG_Intel
Hello RicoBelo,
I wanted to check if you had the chance to try the recommendations I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
RicoBelo
Hello Jed,
Sorry for late answer, I was off last few days and didn't have the opportunity to rebuild a kernel.
I try to do this ASAP then I'll come back to you to inform of the results.
Eric
RicoBelo
Finally had time to buid a 6.17 kernel and test
root@jellyfin:~# uname -a
Linux jellyfin 6.17.7 #2 SMP PREEMPT_DYNAMIC Thu Nov 13 10:33:37 CET 2025 x86_64 GNU/Linux
root@jellyfin:~# dmesg| grep -i iwl.*firm
[    2.829316] iwlwifi 0000:00:14.3: loaded firmware version 89.4d42c933.0 so-a0-hr-b0-89.ucode op_mode iwlmvm
Again The regulatory informations are strictly identical:
root@jellyfin:~# iw reg get
global
Then I tried my hostapd configs with and without DFS, with the same results:
WithDFS:
Configuration file: hostapd.dfs.conf
ctrl_interface_group=0
nl80211: TDLS supported
nl80211: TDLS external setup
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:8
nl80211: Supported cipher 00-0f-ac:9
nl80211: Supported cipher 00-0f-ac:6
nl80211: Supported cipher 00-0f-ac:11
nl80211: Supported cipher 00-0f-ac:12
nl80211: Using driver-based off-channel TX
nl80211: Driver-advertised extended capabilities (default) - hexdump(len=8): 04 00 00 00 00 00 00 40
nl80211: Driver-advertised extended capabilities mask (default) - hexdump(len=8): 04 00 00 00 00 00 00 40
nl80211: Driver-advertised extended capabilities for interface type STATION
nl80211: Extended capabilities - hexdump(len=10): 04 00 c0 00 00 00 00 c0 01 20
nl80211: Extended capabilities mask - hexdump(len=10): 04 00 c0 00 00 00 00 c0 01 20
nl80211: Use separate P2P group interface (driver advertised support)
nl80211: Enable multi-channel concurrent (driver advertised support)
nl80211: use P2P_DEVICE support
nl80211: key_mgmt=0x1ff0f enc=0x76f auth=0x7 flags=0x4800d30fb5bfbe0 rrm_flags=0x19 probe_resp_offloads=0x0 max_stations=0 max_remain_on_chan=10000 max_scan_ssids=20
nl80211: interface wlo1 in phy phy0
nl80211: Set mode ifindex 3 iftype 3 (AP)
nl80211: Setup AP(wlo1) - device_ap_sme=0 use_monitor=0
nl80211: Subscribe to mgmt frames with AP handle 0x5560f1e8d7b0
nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0x5560f1e8d7b0 match= multicast=0
nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0x5560f1e8d7b0 match= multicast=0
nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0x5560f1e8d7b0 match= multicast=0
nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0x5560f1e8d7b0 match= multicast=0
nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0x5560f1e8d7b0 match= multicast=0
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x5560f1e8d7b0 match= multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5560f1e8d7b0 match=04 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5560f1e8d7b0 match=0501 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5560f1e8d7b0 match=0503 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5560f1e8d7b0 match=0504 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5560f1e8d7b0 match=06 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5560f1e8d7b0 match=08 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5560f1e8d7b0 match=09 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5560f1e8d7b0 match=0a multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5560f1e8d7b0 match=11 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5560f1e8d7b0 match=12 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x5560f1e8d7b0 match=7f multicast=0
rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0
nl80211: Add own interface ifindex 3 (ifidx_reason -1)
nl80211: if_indices[16]: 3(-1)
nl80211: Add own interface ifindex 6 (ifidx_reason 3)
nl80211: if_indices[16]: 3(-1) 6(3)
nl80211: Adding interface wlo1 into bridge br0
nl80211: Do not open EAPOL RX socket - using control port for RX
phy: phy0
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
wlo1: interface state UNINITIALIZED->COUNTRY_UPDATE
Previous country code FR, new country code FR
nl80211: No channel number found for frequency 5905 MHz
nl80211: Regulatory information - country=00
hw vht capab: 0x33907132, conf vht capab: 0x1030
DFS support is enabled
Completing interface initialization
Mode: IEEE 802.11a  Channel: 100  Frequency: 5500 MHz
DFS 4 channels required radar detection
DFS all channels available, (SKIP CAC): no
DFS 0 chans unavailable - choose other channel: no
wlo1: interface state COUNTRY_UPDATE->DFS
DFS start CAC on 5500 MHz
wlo1: DFS-CAC-START freq=5500 chan=100 sec_chan=0, width=1, seg0=106, seg1=0, cac_time=60s
80/80+80 MHz: no second channel offset
Can't set freq params
DFS start_dfs_cac() failed, -1
Interface initialization failed
wlo1: interface state DFS->DISABLED
wlo1: AP-DISABLED
wlo1: Unable to setup interface.
hostapd_interface_deinit_free(0x5560f1e82970)
hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1
hostapd_interface_deinit(0x5560f1e82970)
wlo1: interface state DISABLED->DISABLED
hostapd_bss_deinit: deinit bss wlo1
wlo1: Deauthenticate all stations
nl80211: send_mlme - da=ff:ff:ff:ff:ff:ff noack=0 freq=0 no_cck=0 offchanok=0 wait_time=0 no_encrypt=0 fc=0xc0 (WLAN_FC_STYPE_DEAUTH) nlmode=3
nl80211: send_mlme - Use bss->freq=0
nl80211: send_mlme -> send_frame_cmd
nl80211: Frame command failed: ret=-22 (Invalid argument) (freq=0 wait=0)
wlo1: AP-DISABLED
hostapd_cleanup(hapd=0x5560f1e84110 (wlo1))
wlo1: CTRL-EVENT-TERMINATING
hostapd_free_hapd_data: Interface wlo1 wasn't started
hostapd_interface_deinit_free: driver=0x5560e2940760 drv_priv=0x5560f1e8ddc0 -> hapd_deinit
nl80211: deinit ifname=wlo1 disabled_11b_rates=0
nl80211: Remove monitor interface: refcount=0
nl80211: Remove beacon (ifindex=3)
netlink: Operstate: ifindex=3 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Set mode ifindex 3 iftype 2 (STATION)
nl80211: Teardown AP(wlo1) - device_ap_sme=0 use_monitor=0
nl80211: Unsubscribe mgmt frames handle 0x8888dde879605f39 (AP teardown)
hostapd_interface_free(0x5560f1e82970)
hostapd_interface_free: free hapd 0x5560f1e84110
hostapd_cleanup_iface(0x5560f1e82970)
hostapd_cleanup_iface_partial(0x5560f1e82970)
hostapd_cleanup_iface: free iface=0x5560f1e82970
Without DFS:
Configuration file: hostapd.nodfs.conf
HT (IEEE 802.11n) with WPA/WPA2 requires CCMP/GCMP to be enabled, disabling HT capabilities
VHT (IEEE 802.11ac) with WPA/WPA2 requires CCMP/GCMP to be enabled, disabling VHT capabilities
HE (IEEE 802.11ax) with WPA/WPA2 requires CCMP/GCMP to be enabled, disabling HE capabilities
nl80211: Subscribe to mgmt frames with AP handle 0x55c840236750
nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0x55c840236750 match= multicast=0
nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0x55c840236750 match= multicast=0
nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0x55c840236750 match= multicast=0
nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0x55c840236750 match= multicast=0
nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0x55c840236750 match= multicast=0
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x55c840236750 match= multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55c840236750 match=04 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55c840236750 match=0501 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55c840236750 match=0503 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55c840236750 match=0504 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55c840236750 match=06 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55c840236750 match=08 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55c840236750 match=09 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55c840236750 match=0a multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55c840236750 match=11 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55c840236750 match=12 multicast=0
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x55c840236750 match=7f multicast=0
phy: phy0
wlo1: AP-DISABLED
hostapd_interface_deinit_free(0x55c84022e970)
hostapd_interface_deinit(0x55c84022e970)
wlo1: AP-DISABLED
hostapd_cleanup(hapd=0x55c840230130 (wlo1))
hostapd_interface_deinit_free: driver=0x55c8089ec760 drv_priv=0x55c840236d40 -> hapd_deinit
nl80211: Unsubscribe mgmt frames handle 0x8888dd40c8abefd9 (AP teardown)
hostapd_interface_free(0x55c84022e970)
hostapd_interface_free: free hapd 0x55c840230130
hostapd_cleanup_iface(0x55c84022e970)
hostapd_cleanup_iface_partial(0x55c84022e970)
hostapd_cleanup_iface: free iface=0x55c84022e970
JedG_Intel
Hello RicoBelo,
Thank you for sharing the output after trying the latest Kernel. We'll continue to troubleshoot the issue and I'll get back to you once I have another update.
Best regards
Jed G.
JedG_Intel
Hello RicoBelo,
After checking with our team, the no Initiate Radiation (IR) indicates that under the current regulatory setting (DFS-UNSET), the channel cannot be actively used until the system first detects another Wi-Fi transmitter operating on that same channel. To proceed further, please try the steps below.
  • Channel Scan: Please perform a scan on the target channel before checking the regulatory settings with iw reg get
  • Verify Country Code Change: After scanning, check if the regulatory domain updates to France:
phy#0 (self-managed) country FR: DFS-UNSET
(Ensure country_code=FR is configured in hostapd.conf file)
  • Network Manager: Consider enabling and running NetworkManager, as it typically handles the necessary regulatory and dependency configurations required for proper AP mode operation.
If the issue persists, please let me know.
Best regards
Jed G.
RicoBelo
Hi Jed,
I rebooted the computer to get everything at initial state, then requested regulatory info, which displays "00: DFS-UNSET" as usual, then started a scan with the command "iw dev wlo1 scan ap-force", and finally re-checked the regulatory domain: it switched to FR, but remained in "DFS-UNSET" state.
I can't figure how to unlock this "DFS-UNSET" issue !
Logs are in attachments.
I also tried to start hostapd after that in DFS mode, both requesting channel 100 & 106 in 80MHz band, and in a second attempt using ACS scan.
Both failed as usual.
hostapd logs are also in attachments.
Eric
JedG_Intel
Hello RicoBelo,
Thank you for the feedback. I'll check this further with our team for us to get to the bottom of this. I'll give you another update as soon as it's available.
Best regards
Jed G.
