Wireless
8528 Discussioni
Intel AX211 WiFi KEEPS DISCONNECTING!!!
firat
Principiante
1.468Visualizzazioni
Hi!
I am searching all forums but there is no way to connect internet with Intel AX211!
Driver updates, previous drivers, clean install etc! Nothing works!
Do something for it! Maybe thousands of people have the same problem!
Really it is disgusting! And why dont you have turkish language support!!
6 Risposte
JedG_Intel
Moderatore
1.408Visualizzazioni
Hello firat,
I would like to extend my apologies for any inconvenience that this issue has caused on your end. For me to address this properly, please share the information below.
1. Is this working fine before?
2. Are there any error messages on the device manager?
3. Is this a laptop or desktop system?
4. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
5. Are you able to connect to Wi-Fi using a different device?
Please generate SSU report if possible for me to check your system components and configuration.
Jed G.
firat
Principiante
1.297Visualizzazioni
Hi.
Thank you for your answer.
1-It is a new laptop.
2-No, there is no error message, it is disconnecting suddenly and very often.
3-Laptop
4-No,neverchanged, all original and new
5-Yes. But it is still disconnecting when i use it via wireless. And there is not ethernet port. My modem is "TP-Link TD-W9970V3". Perhaps it is causing problem.it works on 2.4 ghz freq.
Whatever i did, it is not working. Connecting and then suddenly discconecting. But seriously thousands of users having the same problem as me. Latest driver or previous drivers didnt solve my problem.
I am sending ssu report.
# SSU Scan Information
Scan Info:
Version:"4.0.0.0"xxxxxxxxxxx
# Scanned Hardware
Computer:
- "Motherboard"
BIOS:"1.07.09TFB, INSYDE - 2"
Caption:"Anakart"
Chipset:"Not Available"
Date:"10.01.2024 12:00 ÖÖ"
Install Date:"Not Available"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Manufacturer:"MONSTER"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Product:"TULPAR T6 V3.1"
Serial Number:"Not Applicable"
Status:"OK"
Version:"Not Applicable"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06.21.2006 12:00 ÖÖ"
Driver Path:"C:\WINDOWS\system32\drivers\bthpan.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.26100.1150"
Index:"0012"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"03.05.2025 04:28 ÖS"
MAC Address:"xxxxx"
Manufacturer:"Microsoft"
Net Connection ID:"Bluetooth Ağ Bağlantısı"
NetCfgInstanceId:"{Axxxxxx}"
PNP Device ID:"BTH\MS_BTHPAN\xxxxxx"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
Type:"Ethernet 802.3"
- "Service Bindings"
Bağlantı Katmanı Topolojisi Bulma Eşleyicisi G/Ç Sürücüsü:
Bağlantı Katmanı Topolojisi Bulma Yanıtlayıcısı:
İnternet Protokolü Sürüm 4 (TCP/IPv4):
İnternet Protokolü Sürüm 6 (TCP/IPv6):
Microsoft Ağları için Dosya ve Yazıcı Paylaşımı:
Microsoft Ağları için İstemci:
Microsoft LLDP Protokolü Sürücüsü:
- "Intel(R) Wi-Fi 6E AX211 160MHz"
- "Caption":"Intel(R) Wi-Fi 6E AX211 160MHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Wi+Fi+6E+AX211+160MHz"
Default IP Gateway:"192.168.1.1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"03.05.2025 11:16 ÖS"
DHCP Lease Obtained:"03.05.2025 10:16 ÖS"
DHCP Server:"192.168.1.1"
Driver:"Netwtw14.sys"
Driver Date:"06.02.2025 12:00 ÖÖ"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\netwtw6e.inf_amd64_70d493b22a8d309e\Netwtw14.sys"
Driver Provider:"Intel"
Driver Version:"23.120.0.3"
ETrackID:"Not Available"
Index:"0010"
INF:"oem15.inf"
INF Section:"Install_GEN_SLR_GfP2_211_AX_6G_2x2_WinT"
Installed:"Yes"
IP Address:"192.168.1.102;fe80::xxxxxx"
IP Subnet:"255.xxxxxx"
MAC Address:"xxxxxxxxx"
Manufacturer:"Intel Corporation"
Net Connection ID:"Wi-Fi"
NetCfgInstanceId:"{xxxxxxx}"
NVM Version:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_xxxxxxxx"
Power Management (Low Power):"Active: Yes, Enable: No"
Power Management (Wake On LAN):"Active: Yes, Enable: No"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Intel(R) Wi-Fi 6E AX211 160MHz"
Service Name:"Netwtw14"
Status:"Enabled"
QoS Paket Zamanlayıcısı:
- "Settings"
*DeviceSleepOnDisconnect:WoWLAN Bağlantı Kesintisinde uyku durumuna geç:"Devre dışı (0)"
*PacketCoalescing:Paket Birleştirme:"Devre dışı (0)"
*PMARPOffload:WoWLAN için ARP yük boşaltma:"Etkin (1)"
*PMNSOffload:WoWLAN için NS yük boşaltma:"Devre dışı (0)"
*PMWiFiRekeyOffload:WoWLAN için GTK yeniden anahtarlama:"Etkin (1)"
*WakeOnMagicPacket:Sihirli Paket Uyanması:"Devre dışı (0)"
*WakeOnPattern:Desen eşleştirme uyanması:"Etkin (1)"
ChannelWidth24:2,4 GHz İçin Kanal Genişliği:"Otomatik (1)"
ChannelWidth52:5 GHz İçin Kanal Genişliği:"Otomatik (1)"
ChannelWidth6:6 GHz İçin Kanal Genişliği:"Otomatik (1)"
CtsToItself:Karışık mod koruması:"RTS/CTS etkin (0)"
FatChannelIntolerant:Geniş Kanal için Uyumsuz:"Etkin (1)"
HumanProximityDetection:İnsan Varlığı Algılama:"Otomatik (0)"
IbssTxPower:Yayın gücü:"5. En yüksek (100)"
IEEE11nMode:802.11n/ac/ax Kablosuz Ağ Modu:"3. 802.11ac (2)"
Is6GhzBandSupported:Ultra Yüksek Bant Genişliği (6 GHz):"Devre dışı (0)"
MIMOPowerSaveMode:MIMO Güç Tasarrufu Modu:"SMPS Yok (3)"
RoamAggressiveness:Gezinme Zorlaması:"3. Orta (2)"
RoamingPreferredBandType:Yeğlenen Bant:"2. 2,4 GHz bant Tercih Et (1)"
ThroughputBoosterEnabled:Verimlilik Arttırıcı:"Devre dışı (0)"
uAPSDSupport:U-APSD Desteği:"Devre dışı (0)"
WirelessMode:802.11a/b/g Kablosuz Ağ Modu:"3. 2,4 GHz 802.11g (16)"
- "Realtek PCIe GbE Family Controller"
Caption:"Realtek PCIe GbE Family Controller"
DHCP Enabled:"Yes"
Driver:"rt640x64.sys"
Driver Date:"05.24.2024 12:00 ÖÖ"
Driver Path:"C:\WINDOWS\system32\drivers\rt640x64.sys"
Driver Provider:"Realtek"
Driver Version:"10.72.524.2024"
Index:"0000"
INF:"oem57.inf"
INF Section:"RTL8168HSS.ndi.NT"
Installed:"Yes"
MAC Address:"xxxxxx"
Manufacturer:"Realtek"
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{9ACC162B-xxxxxxxxxx}"
PNP Device ID:"PCI\VEN_10EC&DEV_xxxxxxxxxxxxx"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Product Type:"Realtek PCIe GbE Family Controller"
Service Name:"rt640x64"
Status:"Enabled"
- "Settings"
*EEE:Enerji Tasarruflu Ethernet:"Etkinleştirildi (1)"
*FlowControl:Akış Denetimi:"Rx & Tx Etkinleştirildi (3)"
*InterruptModeration:Hafifletmeyi Kes:"Etkinleştirildi (1)"
*IPChecksumOffloadIPv4:IPv4 Boşaltmayı Sağla:"Rx & Tx Etkinleştirildi (3)"
*JumboPacket:Jumbo Çerçeve:"Devre Dışı Bırakıldı (1514)"
*LsoV2IPv4:Boşaltmayı Geniş Gönder v2 (IPv4):"Etkinleştirildi (1)"
*LsoV2IPv6:Boşaltmayı Geniş Gönder v2 (IPv6):"Etkinleştirildi (1)"
*ModernStandbyWoLMagicPacket:Wake on magic packet when system is in the S0ix power state:"Devre Dışı Bırakıldı (0)"
*NumRssQueues:En Fazla RSS Sırası Sayısı:"4 Sıra (4)"
*PMARPOffload:ARP Yük Boşaltma:"Etkinleştirildi (1)"
*PMNSOffload:NS Yük Boşaltma:"Etkinleştirildi (1)"
*PriorityVlanTag:Öncelik & VLAN:"Öncelik & VLAN Etkinleştirildi (3)"
*ReceiveBuffers:Arabellekleri Al:"1024 (1024)"
*RSS:Yan Ölçüyü Al:"Etkinleştirildi (1)"
*SelectiveSuspend:Selective Suspend:"Etkinleştirildi (1)"
*SpeedDuplex:Hız & İkili:"Otomatik Görüşme (0)"
*SSIdleTimeout:Selective Suspend Idle Timeout:"50 (50)"
*TCPChecksumOffloadIPv4:TCP Boşaltmayı Sağla (IPv4):"Rx & Tx Etkinleştirildi (3)"
*TCPChecksumOffloadIPv6:TCP Boşaltmayı Sağla (IPv6):"Rx & Tx Etkinleştirildi (3)"
*TransmitBuffers:Arabellekleri İlet:"128 (128)"
*UDPChecksumOffloadIPv4:UDP Boşaltmayı Sağla (IPv4):"Rx & Tx Etkinleştirildi (3)"
*UDPChecksumOffloadIPv6:UDP Boşaltmayı Sağla (IPv6):"Rx & Tx Etkinleştirildi (3)"
*WakeOnMagicPacket:Sihirli Paket Eşleştirme Uyanması:"Etkinleştirildi (1)"
*WakeOnPattern:Desen eşleştirme uyanması:"Etkinleştirildi (1)"
AdvancedEEE:Advanced EEE:"Devre Dışı Bırakıldı (0)"
AutoDisableGigabit:Gigabit’i (PowerSaving) Otomatik Olarak Devredışı Bırak:"Devre Dışı Bırakıldı (0)"
EnableGreenEthernet:Yeşil Ethernet:"Etkinleştirildi (1)"
GigaLite:Gigabit Lite:"Etkinleştirildi (1)"
PowerSavingMode:Power Saving Mode:"Etkinleştirildi (1)"
RegVlanid:VLAN ID:"0 (0)"
S5WakeOnLan:Yerel Ağ Üzerinden Kapat:"Etkinleştirildi (1)"
WolShutdownLinkSpeed:WOL & Kapatma Bağlantı Hızı:"10 Mbps Önce (0)"
...#SSU#...
firat
Principiante
1.375Visualizzazioni
1-Its a new laptop
2.No
3-Laptop
4-All original and new
5-Same, disconnecting always
By the way you can google it. Thousands of people having the same problem. Latest driver didnt work for me.
And my modem is 2.4 ghz.  TD-W9970
here is the ssu report
Scan Info:
Version:"4.0.0.0"
Date:"03.05.2025"
Time:"00:00:06.7156599"
# Scanned Hardware
Computer:
- "Motherboard"
Caption:"Anakart"
Status:"OK"
- "Networking"
DHCP Enabled:"Yes"
Driver:"bthpan.sys"
Index:"0012"
INF:"bthpan.inf"
Installed:"Yes"
Status:"Enabled"
DHCP Enabled:"Yes"
Index:"0010"
INF:"oem15.inf"
Installed:"Yes"
Status:"Enabled"
- "Settings"
DHCP Enabled:"Yes"
Index:"0000"
INF:"oem57.inf"
Installed:"Yes"
MAC Address:"xxxxx"
Status:"Enabled"
- "Settings"
...#SSU#...
JedG_Intel
Moderatore
1.342Visualizzazioni
Hi firat
Thank you for sharing all this information.
Based on the information you provided, it appears that the connectivity issue is affecting all devices, suggesting that the problem may not lie with the Wi-Fi adapter itself. I recommend checking with your Internet Service Provider (ISP) as the issue could potentially be with your router.
Additionally, please note that the product you are reporting is an Original Equipment Manufacturer (OEM) device. Our support may be limited as we may not be fully familiar with the technology, settings, and customizations implemented by the OEM on your system. Furthermore, we recommend using the drivers provided by the Original Equipment Manufacturer (OEM) rather than the generic drivers from Intel. Have you had the opportunity to try this?
It would also be helpful if you could attach the SSU (System Support Utility) file directly, so I can review it more thoroughly.
Jed G.
JedG_Intel
Moderatore
1.239Visualizzazioni
Hi firat,
I'm checking to see if you were able to check my previous post. Please let me know if you have other questions or concerns so that I can help you with it.
Jed G.
JedG_Intel
Moderatore
1.161Visualizzazioni
Hello firat,
I would also like to share this article with you as you might find it helpful:
Intel® Wireless Adapter Keeps Disconnecting from the Network. You may also try downloading the drivers from your OEM for further troubleshooting.
Furthermore, since I have not heard back from you so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
Rispondere
