Wireless
8718 Discussions
Intel Centrino Wireless-N 135 Bluetooth Problem
LVolk
Hey,
I actually have the Problem that I'm unable to use Bluetooth at my Win 8.1 Laptop. I installed the Drivers that the Intel® Driver Update Utility said but after I installed the drivers it's still said that there are new drivers available.
Also there is no Bluetooth option in the Settings of my Laptop.
Any help would be highly appreciated.
Allan_J_Intel1
Thanks for Wireless Networking community.
I understand Bluetooth is not working on the computer and you have a problem that says new drivers are available after using driver utility.
At this point, Intel engineering is working to correct this matter, we are aware that this is a known issue and it should be corrected shortly.
In regards to Bluetooth settings, please make sure Bluetooth devices are enabled. Also, if you already installed the latest Bluetooth driver, there should be an icon on the system tray where you can open Bluetooth settings and enable devices to find your computer.
Allan.
Allan_J_Intel1
Allan.
LVolk
Hey thanks for your help
I actually hadn't activated the Bluetooth device, but I didnt knew how to activate it without the settings.
Now I found a way and now Bluetooth works fine
Lukas
Allan_J_Intel1
I am glad your computer is working again. Thanks for sharing your results.
Allan.
