The wireless card is detected as
00:14.3 Network controller: Intel Corporation CNVi: Wi-Fi
Subsystem: Intel Corporation Device 0034
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 16
Region 0: Memory at 6001144000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [c8] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [40] Express (v2) Root Complex Integrated Endpoint, IntMsgNum 0
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag- RBE- FLReset+ TEE-IO-
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr+ NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
DevCap2: Completion Timeout: Range B, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp- 10BitTagReq- OBFF Via WAKE#, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 16ms to 55ms, TimeoutDis-
AtomicOpsCtl: ReqEn-
IDOReq- IDOCompl- LTR+ EmergencyPowerReductionReq-
10BitTagReq- OBFF Disabled, EETLPPrefixBlk-
Capabilities: [80] MSI-X: Enable- Count=16 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
dmesg is showing this error
[ 6.553868] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 6.556986] iwlwifi 0000:00:14.3: Detected crf-id 0x1300202, cnv-id 0x80400 wfpm id 0x80000030
[ 6.559710] iwlwifi 0000:00:14.3: PCI dev 54f0/0034, rev=0x370, rfid=0x105110
[ 6.561943] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9560 160MHz
[ 6.564504] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-89.ucode failed with error -2
[ 6.567622] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-89.ucode
[ 6.571845] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-88.ucode failed with error -2
[ 6.574917] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-88.ucode
[ 6.579313] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-87.ucode failed with error -2
[ 6.582379] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-87.ucode
[ 6.586689] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-86.ucode failed with error -2
[ 6.589784] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-86.ucode
[ 6.594072] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-85.ucode failed with error -2
[ 6.597134] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-85.ucode
[ 6.601308] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-84.ucode failed with error -2
[ 6.604712] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-84.ucode
[ 6.608861] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-83.ucode failed with error -2
[ 6.612170] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-83.ucode
[ 6.616341] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-82.ucode failed with error -2
[ 6.619379] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-82.ucode
[ 6.623867] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-81.ucode failed with error -2
[ 6.626932] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-81.ucode
[ 6.631278] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-80.ucode failed with error -2
[ 6.637363] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-80.ucode
[ 6.644337] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-79.ucode failed with error -2
[ 6.650306] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-79.ucode
[ 6.657319] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-78.ucode failed with error -2
[ 6.661059] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-78.ucode
[ 6.667633] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-jf-b0-77.ucode failed with error -2
[ 6.674773] iwlwifi 0000:00:14.3: Falling back to sysfs fallback for: iwlwifi-so-a0-jf-b0-77.ucode
[ 6.678877] iwlwifi 0000:00:14.3: no suitable firmware found!
[ 6.683960] iwlwifi 0000:00:14.3: minimum version required: iwlwifi-so-a0-jf-b0-77
[ 6.686314] iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-so-a0-jf-b0-89
[ 6.688697] iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
I have gone into the mentioned repo and copied the files into /lib/firmware but I get the same error. What do I need to do to get it working?
Hello Chronigan,
To better understand the root of the issue, I would appreciate more information about your system. Please provide the following key details:
- Is your system a desktop PC (pre-built or custom-built) or a laptop?
- Is the wireless adapter pre-installed in your system?
- Could you share a link to your system specifications?
- Is this a newly set up system with an out-of-the-box issue, or did it work previously before encountering problems?
- Were there any changes made prior to experiencing this issue?
JeanetteC.
Hello Chronigan,
Michael L.
