Wireless
8117 Discussions
Intel Driver & Support Assistant does not see BE200 installed and working?
irvsp
I had an Intel AX1650i M.2 card in my PC. I swapped it out for a WiFi 7 BE200. Now the Intel Driver & Support does not see any Wifi device? It did before.
I deleted and re-install the Assistant, still doesn't show it. Also tried refreshing my configuration (it did not say it was stale though) and it still is not seen?
Any idea's why or suggestions?
The card is working fine and does connect to a 6Ghz SSID and performs well.
irvsp
Never mind, after checking BIOS that it was seen (and it was) I booted and it is working fine now?
