Wireless
8667 Discussions
Intel Drivers, Cisco 9800 wireless controllers and 802.11r
u2637ps
Wifi adapter AC 9560 160MHz driver version 23.110.0.5. Speaking to Cisco 9800 wlc version 17.9.6
The above driver supports DOT11R but when I connect to Work when I have connected to another wifi network like my home network it is not seen by the Cisco WLC as DOT11R capable. If I turn off the wifi adapter and delete the RSN pmkid on the controller and rejoin it sees it as DOT11r capable. My question is on windows is their a way of asking the Wifi adapter to prefer Fast transition and 802.1x first as it connects and fall back to 802.1x if it can't connect
Mike_Intel
Hello u2637ps,
  1. What is the brand and model of your system?
  2. Was it working fine before?
  3. If yes, did you change any settings before the issue started?
  4. Can you share some screenshots if you receive an error message?
  5. Did you upgraded the wireless controller or this is the original embedded wireless controller of your system?
  6. What are the troubleshooting steps that you tried so far?
Michael L.
u2637ps
Hi
 Lenovo T490 wifi
 It does connect but it does not connect on the Cisco Device as DOT11r if it has been connected to an       alternative Wifi also if  there is no PMK cache on the Wifi Lan Controller it will connect as DOT11r
  No setting were changed from when it fails to connect as DOT11r or when it connects as RSN
       Screen shots of error?
  No error as such exists rather depending on the scenario above it connects as DOT11r or it doesn't.
  No change has occurred since before I have seen the error.
   Checked out that the synopsis can be replicated and it can
         Raised a Cisco TAC case.
Mike_Intel
Hello u2637ps,
Thank you for the update.
Let me also gather the SSU logs of your system that I will use to check your inquiry about fast transition.
Please refer to the link below on how to generate the SSU logs:
Michael L.
u2637ps
Hi
I have the file. It won't automatically send. I really don't want to add it here where can I send it?
regards
Mike_Intel
Hello u2637ps,
Michael L.
Mike_Intel
Hello u2637ps,
I understand if you don't want to share the SSU logs here. You can send it to me via direct message then update this thread for me to check it.
Michael L.
Mike_Intel
Hello u2637ps,
I am just making a follow up on the SSU logs that I requested.
Michael L.
JedG_Intel
Hi u2637ps,
I'm just following up with regards to the SSU report that Mike requested. I sent you an email with regards to this and please check your inbox at your earliest convenience.
Jed G.
u2637ps
Please send me an email off site that I can use and refeence the case and I will send you the file
Mike_Intel
Hello u2637ps,
I received the SSU logs and found out that you are using an older driver version 23.110.0.5.
You can try to download and install our latest generic driver version 23.120.0 from the link below then tell us if this one will work:
https://www.intel.com/content/www/us/en/download/19351/intel-wireless-wi-fi-drivers-for-windows-10-and-windows-11.html
Michael L.
