Pretty much having the identical problem outlined here: https://forums.intel.com/s/question/0D50P0000490S66SAE/intel-dual-band-ac-7260-continually-losing-network-connection
When I'm at one of my offices, my computer constantly disconnects from the network every 15 minutes or so. I'm doing work, then suddenly everything freezes and I get dropped from the network. If I try to reconnect and check for available networks, it will say there are no available networks found. The only way to regain internet is to turn off Wi-Fi, disable the network adapter, re-enable it, then turn the WiFi back on to search for my network and re-connect. However, this needs to be done every 15-30 minutes. This issue has been persisting for a few months now, but the odd thing is that this issue only happens at this particular office where we use the Xfinity XB6 Gateway Modem/Router. We recently disabled the wireless capabilities from the XB6 and have instead paired with the Google WiFi mesh network, but the problem still persists.
3000023041391.5670583605566194E12, Thank you for posting in the Intel® Communities Support.
For some reason, I am not able to see the information provided in the file, in order for us to provide the most accurate assistance, we just wanted to confirm a few details about your system:
What is the model of the motherboard?
If this is a laptop, what is the model of it?
Is this a new computer?
Did you make any recent hardware/software changes?
Was it working fine before?
The wireless card, did you purchased it separately or did it came installed in the computer?
Which Windows* version are you using?
Did you check with your Internet service provider to make sure the Internet is working properly?
We recommend to install the Intel® Wireless driver provided by the manufacturer of the computer since that driver was customized by them work with your specific platform.
Since the computer is using the Intel® Dual Band Wireless-AC 7260, we can try a clean installation of the Intel® Wireless driver:
The latest Intel® Generic Wireless driver version available is 18.33.17.1, please test that driver:
Alberto R.
A Contingent Worker at Intel
3000023041391.5670583605566194E12, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R.
3000023041391.5670583605566194E12, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Alberto R.
Hi @AlbertR_Intel No, none of the above worked and I'm not sure why you are unable to access the files. I can try uploading them again separately, but I had zipped them at an earlier request. Also, the files will be 3 months old as I am no longer able to generate a wlan report from cmd prompt for some reason.
Got the info from this forum:
The problem is the newer Intel drivers, as many have pointed out.
Now to those remaining, take the steps that intel techs pointed out months ago, which involves:
* removing all intel network software from your 'add/remove applications"
* rolling back your driver version. This is done by going uninstall driver in device manager and choosing 'also remove software' tick box.
* Rescan again so it shows again, then repeat, and repeat, and repeat, till you get sick of repeating!
* Use CCleaner and clean your registry of any shit leftover, use windows disk cleanup etc. (good practise)
* Rescan till nothing shows, restart, repeat.. (now they didn't tell you about this repeating! hehe)
* Most of those who are onto it, won't have to repeat so much, but if you have been stuffing around trying to fix this, then there is a lot of rubbish to clean.
* Reboot
* It will reinstall it, check the version, is it the MS version? We are looking for version: 17.15.0.5 or simular 17x version.
Now you check your wifi, and it should be mint.
Now to stop Windows Update reinstalling the shitest driver from intel again, you can google this:
To anyone still having disconnect issues with the ac-7260 module, please try falling back on the driver version. Doing so has worked for many, including myself.
You can get drivers from Microsoft (Update catalog) here: https://www.catalog.update.microsoft.com/Search.aspx?q=ac-7260 Try drivers prior to 18.33.x.x.
If it works for you, please leave a comment here so others will know.
Unfortunately, that hasn't worked for me either and I still disconnect every few minutes. This is getting so frustrating.
