Wireless
8787 Discussions
Intel Dual Band Wireless-N 7260 linkdown-linkup in case of interferation
VTakh
I have a question regarding wireless driver behaviour.
The use case is next:
PC (Windows 7 x64, driver: Intel Dual Band Wireless-N 7260) connected to the Wi-Fi router (SSID: s1, channel: 11).
On the other network (SSID: s2, channel: 9) two devices are transmitting data via iperf.
After several minutes link on the PC performs re connections to the network.
How is that possible? Is the problem in driver?
I expected just increasing packet loss ratio and delays without looping linkdown-linkup.
Logs from Wi-Fi PROset attached:
Driver Intel Dual Band Wireless-N 7260 17.15.0.5 - log1.txt
Driver Intel Dual Band Wireless-N 7260 18.21.0.2 - log2.txt
Thanks in advance,
Viacheslav.
ASouz7
sbst,
Thank you for the information attached. We have a few recommendations that might improve you experience.
1. Disable Bluetooth* in not in use as this impact on the connection as Bluetooth* and Wi-Fi share the same atennas.
2. Disable Power Saving Options: Control Panel >> Hardware and Sound >> Power Options and then set the High Performance and apply to default settings.
3. Change Advance Power Settings >> Wireless Adapter Settings >> Power Saving Mode and make sure both battery and plugged in are set to Maximum Performance.
4. In Device Manager >> Network Adapters >> Intel® Dual Band Wireless-N 7260, right click on it and select Properties and then select the tab that says Advanced, once you're there, please select the value of U-APSD Support to Disabled.
5. Check the value of Transmit Power and make sure it is set to 5. Highest.
6. Set the Preferred Band to Prefer 2.4GHz band.
7. Set the HT Mode to HT Mode.
8. Set the 802.11n Channel Width for 2.4GHz ti mimited 20GHz.
9. Set the value of Roaming Aggressiveness to Lowest.
10. Set the value of Ad Hoc QoS Mode to WMM Disabled.
You can also try one of the solutions found in these links:
http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005585.html Advanced Wi-Fi Adapter Settings for Network and I/O
http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005661.html?wapkw=technote TechNote: Data Reordering Issue Causing Sporadic Wireless Disconnects...
http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005493.html Quick Checks That Might Improve or Fix Connection Issues for Network...
http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005544.html 802.11n Connectivity Recommended Settings for Wireless
http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000006042.html Improve Your 802.11n Wireless Performance for Network and I/O
