Wireless
8654 Discussions
Intel Killer BE1750s (BE201) doesn't detect 6 GHz wireless
APersonWithAProblem
Hi everyone,
As the title says, I own a laptop (Windows 11 Pro) with the Intel Killer BE1750s wi fi adapter, that doesn't detect any 6 GHz wireless network.
The laptop was purchased in Italy, has italian keyboard layout and the 6 GHz network band is allowed in this country.
The 6 GHz access point works fine because I can connect to it with another laptop that has the MediaTek MT7902 wireless adapter.
What I've tried:
  •  Ubuntu live → doesn't detect 6 GHz netowork
  •  Enable all 6 GHz-related setting in advanced setting → doesn't work
  •  Driver 23.70.2 from Intel → doesn't work
  •  Driver 23.80.1.3 from OEM → doesn't work
  •  Driver 23.160.0 from Intel → doesn't work
If I run the "netsh wlan show drivers" the 6 GHz band is supported, but doesn't work.
PS C:\Windows\system32> netsh wlan show drivers
Interface name: Wi-Fi
    Driver                    : Killer(R) Wi-Fi 7 BE1750s 320MHz Wireless Network Adapter (BE201D2W)
    Vendor                    : Intel Corporation
    Provider                  : Intel
    Date                      : 21/07/2025
    Version                   : 23.160.0.4
    INF file                  : oem476.inf
    Type                      : Native Wi-Fi Driver
    Radio types supported     : 802.11b 802.11g 802.11n 802.11a 802.11ac 802.11ax 802.11be
    FIPS 140 mode supported   : Yes
    802.11w Management Frame Protection supported : Yes
    Hosted network supported  : No
    Authentication and cipher supported in infrastructure mode:
                                Open             None
                                Open             WEP-40bit
                                Open             WEP-104bit
                                Open             WEP
                                WPA-Enterprise   TKIP
                                WPA-Enterprise   CCMP
                                WPA-Personal     TKIP
                                WPA-Personal     CCMP
                                WPA2-Enterprise  TKIP
                                WPA2-Enterprise  CCMP
                                WPA2-Personal    TKIP
                                WPA2-Personal    CCMP
                                Open             Vendor defined
                                WPA3-Personal    CCMP
                                WPA3-Personal    GCMP-256
                                Vendor defined   Vendor defined
                                WPA3-Enterprise 192 Bits GCMP-256
                                OWE              CCMP
                                OWE              GCMP-256
                                WPA3-Enterprise  CCMP
    Number of supported bands : 3
                                2.4 GHz [ 2412 MHz - 2472 MHz]
                                5 GHz [ 5180 MHz - 5885 MHz]
                                6 GHz [ 5955 MHz - 7115 MHz]
    IHV service present       : Yes
    IHV adapter OUI           : [00 00 00], type: [00]
    IHV extensibility DLL path: C:\Windows\System32\DriverStore\FileRepository\netwtw6e.inf_amd64_d488480304e1f365\IntelIHVRouter18.dll
    IHV UI extensibility ClSID: {00000000-0000-0000-0000-000000000000}
    IHV diagnostics CLSID     : {00000000-0000-0000-0000-000000000000}
    Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)
Hope to find a solution to this problem
APersonWithAProblem
Apparently the problem is the Intel LAR / DRS system the problem: the adapter sees which "country code" other access points are transmitting, and if sees codes that doesn't match the allowed one, blocks the 6 GHz band.
It's frustrating to not have control over your own hardware.
I'll wait for a response from Intel.
Mike_Intel
Hello APersonWithAProblem,
  1. What is the brand and model of the system?
  2. Let me also check, did you manually install this Killer BE1750 as an upgrade or this is embedded in the system?
  3. Let me clarify, you purchased the laptop in Italy, and you are still in Italy, but you cannot connect to 6Ghz?
  4. Was there an instance that you were able to connect to 6Ghz? If yes, can you tell me how were you able to connect to 6Ghz?
Michael L.
APersonWithAProblem
Hello Mike,
1. MSI Prestige 16 AI+ Evo B2VMG;
2. Is embedded in the system, never touched anything inside;
3. Yes, yes, yes;
4. No, never with this laptop.
I already contacted MSI support and they told me that there in nothing locked at BIOS level.
APersonWithAProblem
Since no one is answering me, I'm publishing further details to better document the problem.
This is the result of the command "netsh wlan show wirelesscapabilities"
PS C:\Windows\system32> netsh wlan show wirelesscapabilities
Wireless System Capabilities
    Number of antennas connected to the 802.11 radio (value not available)
    Max number of channels the device can operate on, simultaneously (value not available)
    Co-existence Support                        : Unknown
Wireless Device Capabilities
    WDI Version (Windows)                       : 0.2.0.13
    WDI Version (IHV)                           : 0.2.0.12
    WiFiCx Version (Windows)                    : 1.2
    WiFiCx Version (IHV)                        : 1.2
    Firmware Version                            :
    Station                                     : Supported
    Soft AP                                     : Not supported
    Network monitor mode                        : Not supported
    Wi-Fi Direct Device                         : Supported
    Wi-Fi Direct GO                             : Supported
    Wi-Fi Direct Client                         : Supported
    Protected Management Frames                 : Supported
    DOT11k neighbor report                      : Supported
    ANQP Service Information Discovery          : Supported
    Action Frame                                : Supported
    Diversity Antenna                           : Unknown
    IBSS                                        : Not Supported
    Promiscuous Mode                            : Not Supported
    P2P Device Discovery                        : Supported
    P2P Service Name Discovery                  : Supported
    P2P Service Info Discovery                  : Not Supported
    P2P Background Discovery                    : Supported
    P2P GO on 5 GHz                             : Supported
    P2P GO on 6 GHz                             : Supported
    P2P Sae on GO                               : Supported
    ASP 2.0 Service Name Discovery              : Not Supported
    ASP 2.0 Service Information Discovery       : Not Supported
    IP Docking Capable                          : Not Supported
    Host FIPS Mode                              : Supported
    Instant Connect                             : Supported
    Dx Standby NLO                              : Supported
    Extended Channel Switch Announcement        : Supported
    Function Level Reset                        : Not Supported
    Platform Level Reset                        : Supported
    Bus Level Reset                             : Supported
    MAC Randomization                           : Supported
    Fast Transition                             : Supported
    MU-MIMO                                     : Supported
    Miracast Sink                               : Supported
    BSS Transition (802.11v)                    : Supported
    IHV Extensibility Module Configured         : Supported
    SAE Authentication                          : Supported
    SAE Hash-to-Element Authentication          : Supported
    WPA3 SUITE-B Authentication                 : Not Supported
    OWE Authentication                          : Supported
    FTM as Initiator                            : Not Supported
    MBO Support                                 : Supported
    Number of Tx Spatial Streams                : 2
    Number of Rx Spatial Streams                : 2
    Number of Concurrent Channels Supported     : 0
    Number of Radios                            : 0
    P2P GO ports count                          : 1
    P2P Clients Port Count                      : 1
    P2P Max Mobile AP Clients                   : 8
    Max ANQP Service Advertisements Supported   : 0
    Maximum Number of Secondary STAs Supported  : 0
    Number of MLO Connections Supported         : 4
    Wi-Fi 7 Enterprise                          : Not Supported
    QoS MSCS Supported                          : Supported
    QoS DSCP to UP Mapping Supported            : Supported
    Max Number of Wake on Incoming Action Frame Patterns Supported: 2
    Wpa3-Sae with 384-bit Pmk Supported         : Supported
    Cross Akm/Cipher Roaming                    : Supported
    Co-existence Support                        : Wi-Fi performance is maintained
Mike_Intel
Thank you for the update.
Let me share this link:
How to Enable 6 GHz Band Using Intel® Wi-Fi 6E or Wi-Fi 7 Products
Please help generate the SSU logs of your system for me to further check the hardware and the installed driver. Kindly refer to the link below on how to generate the logs.
Michael L.
APersonWithAProblem
Good morning. Tomorrow I will post the SSU
APersonWithAProblem
Here is the SSU
Mike_Intel
Let me share these links and kindly try to perform clean install of the driver and Killer Performance Suite of you are using the app.
Clean Installation of Wireless Drivers
How to Perform a Clean Installation to Solve Most Intel® Killer™...
As additional information, let me also share this link:
Wi-Fi 6 vs. Wi-Fi 6E/7: Understanding 6 GHz Band Support Differences
Michael L.
APersonWithAProblem
Hello Mike,
I've performed a clean driver installation, and I still can't detect 6 GHz network.
Also like a month ago I formatted Windows 11: also before this, the 6 GHz wasn't working.
What do I need to do to get 6GHz working on this 1600€ laptop?
Thank you
Mike_Intel
Here is the generic driver from Intel that you can try and perform clean driver installation. I did not include this in my previous post because in your initial post you already tried this version.
Intel® Wireless Bluetooth® Drivers for Windows® 10 and Windows 11*
If you are still having the same issue after trying the Intel generic driver, you may try to contact the manufacturer of the laptop to further check if the laptop is capable of 6Ghz. Here is the link for the OEM driver:
MSI Global - The Leading Brand in High-end Gaming & Professional Creation | MSI Global - The Leading Brand in High-end Gaming & Professional Creation
Let me explain the difference between generic and OEM driver. The difference between OEM and generic drivers is OEM drivers may contain custom settings or modifications for the controllers and generic driver from Intel is the normal driver. That is why most of the time, it is recommended to use the OEM drivers.
Michael L.
Mike_Intel
Michael L.
APersonWithAProblem
As written on my reply on 09-03-2025, I already contacted the manufacturer (MSI) and it told me that there is nothing locked at BIOS level nor driver level.
The problem is not solved yet.
Mike_Intel
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
I just want to update you that we are now reviewing this issue and performing further investigations.
For documentation purposes, let me also ask for the following details:
  1. Have you tried to connect using hotspot on the 6ghz band? Please try to further isolate the issue using different access point and tell me the updates and the test that you have done for me to document it.
Michael L.
Mike_Intel
I am just making a follow up to check if you were able to review my last post.
Michael L.
Mike_Intel
I am sending another follow up to check if you tried our last recommendation.
Michael L.
