Wireless
8721 Discussions
Intel My Wifi Dashboard Lite
I have a machine with an Intel Centrino Wireless-N 1000 wifi chip. I want to use the my wifi hotspot feature with it but am running into some issues. I have driver version 15.3 installed, and My Wifi Dashboard 15.2 installed. Both are the latest available versions. I can get the hotspot feature to work with no problems after I install the My Wifi Dashboard. When I open the dashboard, it opens the full version, and I am able to turn on Wifi Direct and Hotspot. It all works great until my machine needs a restart. When I restart, the next time I open the dashboard, it opens the "Lite" version, where I am unable to enable Wifi Direct or Hotspot. The only way I have found to get it to work again is to reinstall Intel My Wifi Dashboard.
Thank you for your post. I also sent you a private message.
Something you can do is update to the latest version of the software and wireless drivers, most of these issues are caused due to driver/software mismatch.
Windows* 7 32 bit download Wireless_15.3.1_s32.exe and for Windows* 7 64 bit download Wireless_15.3.1_s64.exe from the link below:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22116&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22116&lang=eng
and for the latest dashboard in Windows* 7:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3551&DwnldID=22138&keyword=15.%E2%80%8B3.%E2%80%8B1&DownloadType=Software+Applications&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3551&DwnldID=22138&keyword=15.%E2%80%8B3.%E2%80%8B1&DownloadType=Software+Applications&lang=eng
For Windows* 8 32 bit download the file: wireless_15.3.50_e32.exe and fro Windows* 8 64 bit download the wireless_15.3.50_e64.exe form the link below:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22005&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22005&lang=eng
For the dashboard download the latest one from here:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22008&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22008&lang=eng
I hope this helps
Hello , i have the same problem , i cant install My Dashboard full version on my Asus ux31a
what to do ?
