- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I have a laptop running Windows XP Service Pack 3, with an Intel Pro Wireless 2200BG Wireless NIC. I am able to connect to the Aruba Instant Access Point using Windows Zero Configuration, but am unable to connect via the Intel ProSet Wireless WiFi Utility running version 12.4.4.0.
The Access Point is configured to use WPA-2 Personal AES (wpa2-psk-aes). The only options using the Intel ProSet Utility is WPA-2 Personal-AES-CCMP. I don't believe that the Aruba Access point is using the "CCMP" portion. Is there any way to configure the Intel ProSet Utility to connect to the Wireless Connection via WPA-2 Personal AES?
The wireless connection acts like it connects, but fails to get a DHCP address. When using the Wireless Zero Configuration, everything works fine, it's able to connect and get a DHCP address.
Any help would be much appreciated.
Enlace copiado
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
