Wireless
8210 Discussions
Intel Proset Software V15.8 silent install
rgree5
I was hoping for a little assistance with a silent install of Proset Software V15.8. I am attempting to create a Silent XML install that will install the Intel Proset software in the follow way.
Wifi Driver and Enterprise software only
Xpincontrol=true
HideTrayIcon=true
HIdeTaskTrayOOBE=true
If someone could give me a working example of a XML file I would greatly appreciate it
Jose_H_Intel1
Hello Rick74,
The following articles may help you:
Silent installation of wireless drivers and Intel® PROSet/Wireless Software
http://www.intel.com/support/wireless/wlan/sb/CS-030736.htm http://www.intel.com/support/wireless/wlan/sb/CS-030736.htm
Silent installation of wireless components with Setup.xml
http://www.intel.com/support/wireless/wlan/sb/cs-034114.htm http://www.intel.com/support/wireless/wlan/sb/cs-034114.htm
rgree5
Joe_intel,
Thank you for your reply. The links were helpful in selecting which packages will be installed, but I do not see any information on how to set preferences such as Xpincontrol=true, HideTrayIcon=true, IdeTaskTrayOOBE=true.
Am I just missing that information in the links you provided?
Ilene_K_Intel
Rick74,
Which operating systems will you be deploying PROSet to? The commands will differ slightly depending on the OS. If you are using Windows* 7 the following should work. Make sure to follow the upper/lower case settings as those are important. You may also want to search Microsoft's site as they should have additional examples.
Silent
HIDETRAYICON=TRUE HIDETASKTRAYOOBE=TRUE
IleneK
Intel Customer Support
JFeye1
For me the Xpincontrol=true does not work .
You can disable the intel pro utility after the installation and use the windows utility
Via registry:
HKLM\SOFTWARE\Intel\Wireless\GuiConfiguration\Proset7Mode
Value=0
Kr,
Joeri
