Wireless
8721 Discussions
Intel(R) Dual Band Wireless-AC 7260 , migration fail
ehdhkwnj
일부 또는 모호한 일치로 인해 디바이스 PCI\VEN_8086&DEV_08B1&SUBSYS_50708086&REV_93\6C2995FFFF00276F00이(가) 마이그레이션되지 않았습니다.
마지막 디바이스 인스턴스 ID: PCI\VEN_10EC&DEV_8168&SUBSYS_81161019&REV_0C\01000000684CE00000
클래스 GUID: {4d36e972-e325-11ce-bfc1-08002be10318}
위치 경로:
마이그레이션 순위: 0xF000FFFFFFFFF122
표시: false
상태: 0xC0000719
이렇게 나오는데 어떻게 하면 마이그레이션을 성공할수 있을까요?
n_scott_pearson
I am sorry, but we cannot convert the text in the attachments to English, so cannot tell what is going on here. Support is provided in English only. What do you mean by 'migrated'?
Please download and run the Intel System Support Utility for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
