Wireless
8378 Discussions
Intel(R) Wi-Fi 6 AX200 160MHz ist showing wifi is possible
KasperBR
Hi good sirs, i have ran into an issue with my pc's wifi connection i get an error code 56, nothing i do seems to remedy this issue. i have had this pc for 3 years and it has only now started doing this.
as of now i have the pc is an Aorus 15g kc
things i have done include:
- removed the drive on device manage
- updated the driver manually and automatic tried restarting a bunch of times
a friend of mine said it was a known issue on windows 11 and could be solved by either reinstalling windows or going to windows 10. so before then i wanted to see if you had any good workarounds
Thanks you for your time.
Senkuchan
Valued Contributor II
This issue often arises due to misconfigured network settings or conflicts with VPN software.
Here are some steps you can take to fix this issue:
1. Network Reset:
* Open Settings.
* Go to Network & Internet.
* Click on Status.
* Scroll down and click on Network reset.
•Click the Reset now button and confirm by clicking Yes
2.Update Network Drivers:
•Right-click on the device with the Code 56 error in Device Manager.
• Select Update driver.
• Choose Search automatically for drivers to let Windows find and install the appropriate driver
3.Disable VPN Software:
If you have any VPN software installed, try disabling or uninstalling it, as it can sometimes cause conflicts.
4.Run the Network Troubleshooter:
* Press the Windows key. and type troubleshoot.
* Select Network Adapter and click on Run the troubleshooter. Follow the prompts to complete the process
4.Check for BIOS Updates:
• Ensure your BIOS is up to date, as updates can sometimes include fixes for hardware compatibility issues
If the issue is the same, try performing a clean installation [ https://www.intel.com/content/www/us/en/support/articles/000022173/wireless.html ]of the wireless driver and isnstall the latest version. Here’s the link: https://www.intel.com/content/www/us/en/download/19351/intel-wireless-wi-fi-drivers-for-windows-10-and-windows-11.html
