Wireless
7928 Discussions
Intel(R) Wi-Fi 6E AX211 160MHz (netwtw12) wifi disconnects frequently
mahyar
hi wifi keeps disconnecting
i tried evrything but nothing changed
pls help me out
Jose_Intel
Hello @mahyar
Thank you for posting on the Intel️® communities.
We understand you are experiencing issues with your Intel® Wi-Fi 6E AX211 (Gig+), we will be more than happy to assist you.
Please answer the following:
·      When did it start to happen?
·      Have you tried a roll back to a previous driver version for testing?
·      Have you installed any recent software or hardware in your system?
·      Have you checked if this issue happens on different networks?
·      Have you rebooted your access-point, router, modem?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
Jose_Intel
Hello mahyar
We hope you are doing fine.
Were you able to check the previous questions?
Let us know if you still need assistance by attaching the required report.
Jose B.
Jose_Intel
Hello mahyar
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
