Wireless
8608 Discussions
Intel(R) Wi-Fi 6E AX211 160MHz
MSB1
Intel(R) Wi-Fi 6E AX211 160MHz Killer not working
JeanetteC_Intel
Hello MSB1,
I would like to know more about your system details to fully understand where the issue truly lies. Please provide the missing key information here:
1) Is your system a desktop PC or a laptop device?
2) Is this the wireless adapter came pre-installed in your system, or have you changed/installed a new adapter recently?
3) Is this a newly purchased device with an out-of-the-box issue or has it previously worked before it stopped working?
  • If previously worked, what were the changes made before the issue started?
4) Can you describe briefly when you say it is "not working"?
  • Are you getting any error message?
  • Not able to see any wireless networks.
  • Can see available networks but not able to connect.
  • Others: (Please explain briefly)
5) Are you having issues on Wi-Fi or Bluetooth or both?
6) Is this issue happening at home, office environment or both?
Additionally, I highly appreciate you sharing your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save. *Attach the SSU log file as you reply.
JeanetteC.
JeanetteC_Intel
Hello MSB1,
Did you have a chance to review the previous post?
Please feel free to reach out if you have any questions.
JeanetteC.
JeanetteC_Intel
Hello MSB1,
Since I haven't received any response from you recently, I will go ahead and close this thread.
Sincerely,
JeanetteC.
