Wireless
8617 Discussions
Intel Website and Powershell
Clahs
I've made a powershell script that checks your website for the latest Wifi driver, but it seems now I get an Access Denied when I try this. This is used to maintain the driver on the 6000 computer.
Do you have an API or something I can try to connect?
I would be sad to have to manually update all machines.
Yours sincerely
Vipin_S_Intel
Hi Charles, we are routing your thread to the respective team for further help. They will get back to you as soon as possible.
Alberto_R_Intel
ClahsThank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
In reference to this scenario and regarding your question, I will do further research on this matter to try to gather the information you are looking for. As soon as I get any updates, I will post all the details on this thread.
Albert R.
Alberto_R_Intel
Hello Clahs, I just received an update on this matter.
After reviewing the case, from our side, what we recommend to do on this scenario will be to get in contact with Microsoft Support directly for further assistance on this matter since this topic is out of our scope of support:
https://support.microsoft.com/en-us
Albert R.
Clahs
Hi Albert,
Thanks for your reply, but unfortunately Microsoft can't help me.
It is a change Intel have made on the server that blocks this, as it has worked until now.
I have also tried using other tools to read your website, but here that is also blocked. It is not only Powershell.
Don't you have an api approach where you can ask for the latest version?
Handling this driver update on 6000 machines will otherwise be a heavy task.
Yours sincerely
Clahs
Alberto_R_Intel
Hi Clahs, Thank you very much for your response.
I will double-check those details about the API approach you mentioned and provide a response as soon as possible.
Albert R.
Alberto_R_Intel
While we are still working on this scenario, we just wanted to check if you could please provide an updated error code/screenshot as well as the CIDRs/IPS for the requests?
Albert R.
Alberto_R_Intel
Hello Clahs, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello Clahs, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Rels
Hi Clahs,
I would like to get more info on the script and the usage you have, so we can fix the issue you are experiencing.
Can you contact me my email is rafael.lopez@intel.com.
Thank you,
Rafael Lopez
