Morning Folks,
I've had the Intel Wi-Fi 6 AX200 (Gig+) Desktop Kit installed in my PC for months and yesterday it randomly stopped working, and ceased to show up on my device manager for both the Wifi & Bluetooth. Tried reinstalling drivers to no avail.
It's been installed and functioning perfectly for months, and out of the blue, on boot up yesterday the PC isn't recognizing the card anymore. Not sure what to do.
Note: I had to use a key adapter for the connection, but everything has been installed and working without issue, and the PC hasn't moved an inch, so I cannot think of why the connection would break somehow. (Here's the adapter: Sintech M.2 M-Key M.2 Key E Module,NGFF WiFi Card to M.2 Key M Adapter Card Compatible for Intel 726...)
Second Note: My USB wifi adapter works flawlessly (AC 1300M USB WiFi Adapter, 2.4G/5G Wireless WiFi Dongle For Windows 11 / 10/ 8/ 7/ XP Mac 10.7 to 10...)
Hoping and praying someone's got a solution?
Running the Following:
MOBO:
-GIGABYTE Z590 Vision G (LGA 1200/Intel Z590/ATX/3x M.2/PCIe 4.0/USB 3.2 Gen2X2 Type-C/2.5GbE LAN/Motherboard
Processor:
-Intel Core i7-11700K - Core i7 11th Gen Rocket Lake 8-Core 3.6 GHz LGA 1200 125W Intel UHD Graphics 750 Desktop Processor - BX8070811700K
OS:
Windows 10 Pro
Memory:
-SAMSUNG 970 EVO PLUS M.2 2280 2TB PCIe Gen 3.0 x4, NVMe 1.3 V-NAND 3-bit MLC Internal Solid State Drive (SSD) MZ-V7S2T0B/AM
-WD Blue 3D NAND 1TB Internal SSD - SATA III 6Gb/s 2.5"/7mm Solid State Drive - WDS100T2B0A
RAM:
-G.SKILL TridentZ RGB Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) AMD 3000 Compatible Intel XMP 2.0 Desktop Memory F4-3200C16D-32GTZR
Hhmmm, it may have simply died (not unheard of). Move the card carrier to another PCIe connector and see if it works there. If it's still not detected, then you may have to look at an RMA to get it replaced.
