Wireless
8414 Discussions
Intel Wi-Fi 6 AX201 160MHz connection loss
Jackie_Cheng
Notebook brand: HP 440 and H3C Z4
Network card model:Intel Wi-Fi 6 AX201 160MHz
Ap:H3C
Appearance:Lost network connection during use,appear randomly
We Tried changing the driver version several times, but the problem is still not resolved
DeividA_Intel
Hello Jackie_Cheng,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6 AX201 (Gig+).
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Is the Bluetooth working?
4. Do you see any error at the device manager (code 10 or code 43)?
5. Have you checked this issue with HP?
6. What is the exact model of your H3C Access Point?
Deivid A.
DeividA_Intel
Hello Jackie_Cheng,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello Jackie_Cheng,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
Jackie_Cheng
We tried to set No SMPS for the MIMO of the intel ax201 . The situation seems to have improved.
We learned from Intel's official website
https://www.intel.com/content/www/us/en/support/articles/000005585/wireless/legacy-intel-wireless-products.html
"Some legacy APs may have compatibility issue with supporting the SMPS mode and may cause various link quality problems such as low throughput. Change this setting to No SMPS may help to work around the issue."
what is the root cause of this problem?
