Wireless
8651 Discussions
Intel Wi-Fi 6E AX210 Certification Request (AX210NGW)
kevin310
Our company is currently in the process of obtaining CE, FCC, IC, and KC certifications for the robot we've developed.
We need certification documentation for the Intel Wi-Fi 6E module AX210NGW integrated into the robot.
Could you provide the required test reports and certifications for this module?
We'd also like to inquire about the availability of the external PIFA antenna datasheet.
Thank you for your help.
Mike_Intel
Hello kevin310,
  1. Can you further explain why you need the certification? You mentioned that it is for the robots that you developed, but why do you need the certification? Can you tell us more about it?
Michael L.
kevin310
Thank you for your reply.
We are a robot development company located in Korea.
We are using your Wi-Fi module (AX210NGW) for robot firmware updates.
We are developing a single-person electric golf trolley, and development is currently complete and in the process of certification.
Certification is underway for CE (UKCA), FCC, IC, and KC.
Even if we use the certified Wi-Fi module (AX210NGW), the following documents and additional EMC testing are required:
(We need to confirm the RF output and operating band of the Wi-Fi module.)
>Certifications (CE, FCC, IC, KC)
>Certification Test Reports (CE, FCC, IC, KC)
>Approved Antenna Specifications
(We would like to request information on approved antennas that we can purchase.)
(PCB PIFA TYPE ANT)
If direct provision is difficult for security reasons, an NDA with a certification company is also available.
Your cooperation is urgently needed.
Mike_Intel
Hello kevin310,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
Hello kevin310,
I will send an e-mail to the e-mail address associated with your community profile regarding the information you are looking for, please check it out.
Michael L.
Mike_Intel
Hello kevin310,
Michael L.
kevin310
Dear Michael L.
Thank you for your cooperation.
I will proceed as instructed.
I will contact you again if any issues arise.
Thank you.
Mike_Intel
Hello kevin310,
Thank you for the confirmation.
Because of this, I need to close this inquiry.
Michael L.
