Wireless
8630 Discussions
Intel Wi-Fi 6E AX210 Error 43
tstob1
Lost both Wi-fi adapter AX210 and Bluetooth. Yellow bang and Error 43.
Using USB Ethernet adapter.
Windows 11 24H2 26100.2605. Was the same on 23H2
When I install the latest intel drivers they do not show up in the installed apps, only the Bluetooth does. I have uninstalled the adapter and drivers in device manger and rebooted several times.
Acer laptop and no power management tab for the Wi-fi adapter. only Acer power profile available in advanced power settings can not change. no Acer software installed.
RobbieR_Intel
Hello tstob1,
Thank you for reaching out and providing your SSU Log. I understand that you're experiencing issues with your AX201 Wi-Fi adapter and Bluetooth functionality and it is frustrating.
To better assist you, kindly answer the following questions:
  • May I know the exact make and model of your acer laptop?
  • Did you make recent changes to your system?
  • Have you done other troubleshooting steps?
  • Are there any additional logs or warning in the event viewer related to the Wi-Fi or Bluetooth adapters?
Robbie R.
RobbieR_Intel
Hello tstob1,
Robbie R.
RobbieR_Intel
Hello tstob1,
Robbie R.
