hi. I have two laptop :
a . HP 745G4 using intel 7265AC wifi
b. Surface Pro 7 with AX201
Both cant connect to 40Mhz wifi 5Ghz. Im In Indonesia. The regulatory said it is suppose allowed for wifi using 80mhz bandwidth
Please advise
this related to this thread as well. we are in same country
community.intel.com/t5/Wireless/Wifi-AX201-Lock-Wifi-Interface-to-173-3Mbps-Channel-Width-20MHz/m-p/1268280#M34905
Hello @ydenny
We understand you have opened an internal web ticket with us regarding the same issue and environment, and we will continue to help you through that channel now. We will therefore close this community case. Thank you.
Andrew G.
