Wireless
7437 Discussions
Intel Wireless AC 9560 160 MHz Error 10
dante7729
I've had a recurring issue with my Intel wireless AC 9560. I've been unable to connect to wifi networks and under device manger the network adapter displayed a Code 10 Error. I've done clean installs of the wireless and bluetooth drivers and it seems to fix it for a day or so and the issue resurfaces. Sometimes reinstalling the drivers does nothing. Any ideas where to go from here? Could it be a hardware issue? Thanks. I've also attached a scan report. The wireless adapter is currently working well but I don't expect that to last long.
Kanny
Hey there, I just had the same problem, I allways get the same error now and then.
For me, on my Predator Helios 300 worked with a simple windows update. I also tried everything else without any results. Hopefully you have an ethernet cable to be able to update.
Cheers
dante7729
As of March 22 the issue has recurred, I've attached a scan from today. A response would be appreciated, thank you.
Alberto_Sykes
dante7729, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance, we just wanted to confirm a few details about your system:
What is the model of the Router?
Is this a new computer?
Was it working fine before?
When did the issue start?
Did you make any recent hardware/software changes?
The wireless card, did you purchased it separately or did it came installed on the computer?
Does the problem happen at home or work environment?
Albert R.
dante7729
Hi Alberto,
Thanks for the response.
My router is from spectrum and its model is TC8717T
I've had this computer for about a year with no issues.
It's been working fine until this issue started about 2-3 weeks ago.
There haven't been and recent hardware/software changes.
The wireless card came installed.
It's happened both on my home and work networks.
Hope this helps, thanks again.
Alberto_Sykes
Hi dante7729, Thank you very much for providing that information.
Based on the information showing in the SSU report, we can confirm that currently the Wireless driver install on your system is version: 21.60.0.5.
Just to let you know, we always recommend to install the Wireless driver provided by the manufacturer of the computer, since that driver was heavily customized by them to work with your specific platform.
I looked in MSI's website and the latest Wireless driver they have available is version 21.30.3.2, please try a clean installation of that driver following the instructions in the link below:
https://www.msi.com/Laptop/support/GS65-STEALTH-9SD#down-driver&Win10%2064
https://www.intel.com/content/www/us/en/support/articles/000022173/wireless.html
If the problem persists after that, then we can try a clean installation this time of the Intel® Generic Wireless driver version 22.30.0: https://downloadcenter.intel.com/download/30208/Windows-10-Wi-Fi-Drivers-for-Intel-Wireless-Adapters
If the issue remains, please provide an updated SSU report that reflects the changes done:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
dante7729
Hey again Alberto,
I did a clean install of both drivers and the issue still remains. I've attached a scan. Thanks for your help with all this!
Alberto_Sykes
Hi dante7729, You are very welcome, thank you very much for sharing those results.
We are sorry to hear the issue persists after the clean installation of both drivers, we will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
Alberto_Sykes
dante7729, I Just received an update on this matter.
Just to let you know, the code 10 error in general terms is a hardware issue related and must be addressed with the manufacturer of the laptop directly:
https://us.msi.com/support
Now, if you are willing to perform more troubleshooting steps with us, please let us know so we can further assist you with this topic.
Albert R.
dante7729
Hi Alberto,
Thank you for all your help! I'll contact MSI support to resolve the hardware issue.
Alberto_Sykes
Hi dante7729, You are very welcome, thank you very much for sharing those updates.
Perfect, excellent, they should be able to further assist you with this hardware problem, warranty options from them might be necessary.
Any other inquiries, do not hesitate to contact us again.
Albert R.
