Wireless
8623 Discussions
Intel Wireless AC 9560 160MHz slow connection / drop connection problems
KevinTerrero
Hey, for over a week now I´ve been having connection problems. I´ve come down to the conclusion that is the network adapter I´m using on my  MSI GF53 Thin laptop since every other device in my house its working completely fine with the wifi except for my laptop. On the Event Viewer I get the 6062- Lso was triggered everytime this happens. Then the connection gets really slow or it just drops for a couple of minutes. I have tried multiple solutions I found online and so far no of these have worked. Im still getting these random moments where my connection just wont work. I have also read a couple of posts regarding the same issue with the same wifi adapter and tried recommended solutions and the problem is still happening. I have attached my SSU report. Hopefully you can help me solve this problem without me having to replace the wifi adapter.
DeividA_Intel
Hello KevinTerrero,
Thanks for your response. Based on your issue, I would like you to try the following:
1. Perform a clean install of the latest driver:
2. Try the "Recommended Settings for 802.11ac Connectivity" article.
3. Follow the "Quick Checks to Improve or Fix Wi-Fi Connection Issues" article.
4. Run all the operating system updates, including the optional ones.
Deivid A.
DeividA_Intel
Hello KevinTerrero,
Thank you for posting on the Intel® communities. I can imagine how frustrating this is for you.
To have a better understanding, please confirm the following:
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is the Bluetooth working?
3. Did you test a different AP/router/network?
4. Is there an error in the device manager (code 10, code 43)?
5. What is the brand and model name of your AP/router?
6. Is this issue recent or was present out of the box?
Deivid A.
KevinTerrero
Thank you very much for responding!
1. Yes, I have not changed the network adapter to this laptop as of yet.
2. Yes, I use my headphones via bluetooth everyday and they are still working perfectly with this PC.
3. Yes, I have used my cellphone data with this PC and still have the same issue where it disconnects at random moments.
4. I have not seen any errors on my Device Manager as of yet when I was trying to fix this issue. Just to make completely sure of this, where would I see this so I can send u a screenshot of what it looks like.
5. The brand for my router is Huawei.
6. The issue started like a week ago and it was completely random, I´ve had this PC for over 2 years now with the same network adapter and this never happened to me before.
DeividA_Intel
Hello KevinTerrero,
Deivid A.
KevinTerrero
Thank you very much for reaching out back to me!
Thank you for all the possible solutions, I have already installed the latest driver and used the recommended settings for it. Hopefully this solves the issue. I will be trying all this and will reach back if there is any other problem. Enjoy ur holidays, Thank you!
KevinTerrero
Hello again, quick update. Last night when I implemented all the solutions mentioned above, it was working fine (couldn´t test it much cause I was just using Netflix at that time). However, when I tried today, my PC would say it´s connected to the WiFi but it wouldn´t connect at all. So I did the clean install again, which allowed me to connect, and I´m still having the same connection issues where it gets slow, then drops for a while. I´m getting the following event with every web i try to connect to i will be attaching plus the 6062- Lso was triggered still
KevinTerrero
Another quick update. After what I preoviously mentioned, I restarted network and my router. After that my PC has been better just a couple of times connection got lost for a couple of seconds, and slower that it should for brief moments. Also I´m doing speedtest and I´m getting way less download that I´m paying for. This happens just to this PC, every other device is receiving good amounts of download speed. But its been better than before I implemented your solutions.
DeividA_Intel
Hello KevinTerrero,
Thanks for your response. In this case, if the issue persists and this is the only device that is presenting the issue, I recommend you to get in contact with MSI so they can run the tests needed to confirm if this is a hardware or software issue and they can help you with the replacement if needed.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
