I have had this problem since Windows 10 and now on a clean install of Windows 11 Pro 64bit it still happening where every time I connect to an AP WIFI would disconnect and reconnect all by itself cause Intel_PIE_Service.exe (PIEServiceNew)
why is this happening and how I can fix it?
Device: Asus GL504GW
WIFI: Intel Wireless-AC 9560 160MHz (Driver ver: 22.90.0.5)
OS: Windows 11 Pro 64bit 21H2 (10.0.22000)
Hello POQDavid
Thank you for posting on the Intel️® communities. Please share with us the following information:
- Do you get any Bluetooth issues?
- Is this issue happening at home, office environment or both?
- Is this a new computer? If so, have check with your system's OEM for validated drivers or support on known issues related to the symptoms experienced?
- Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
- Does this happen on different networks?
- Is this triggered by a certain action or does it happen randomly?
- Were you able to have you wireless connection in a normal/expected performance before?
- Have tried other drivers? What version?
- Have you rebooted your access-point, router, modem?
David G
Nope Bluetooth is 100% ok
Yes both
Well, my laptop isn't new but the OS is fresh Windows 11 Pro 64bit and I do have the right drivers
Nope it's the original adapter
It happens with any AP
it's never randomly it's always when I connect to AP and once I do it goes off and reconnects
and it would do that again if i reconnect
Nope it's been like this since Windows 10
So far all versions gave me the same problem
Yes I do and I am sure my AP is fine
Thanks for the update. Please share with us the Intel® System Support Utility (Intel® SSU) results to investigate:
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
David G
Sorry for the delay here is the SSU file you asked for I hope it helps
Please make sure you're using:
- Recommended Settings for 802.11ac Connectivity
- Advanced Intel® Wireless Adapter Settings
If you use those settings, tried different routers and the issue persists please contact Asus for more steps because there could be an issue with the card or laptop.
David G
David G.
David G.
Sorry I didn't had access to my account for some reason was broken where it didn't allow me to login
but I did a lot more testing and noticed when the Network Location Awareness service is enabled and I use my DNSCrypt DNS it makes the WIFI disconnect from the AP and reconnects
the thing is Intel_PIE_Service.exe also restarts when that happens i did sent them a ticket too here
