Wireless
7864 Discussions
Intel Wireless Adapter Support for 802.11k, 802.11v, and 802.11r
RSaku
Hi, referring to the following articles on support for 802.11k, 802.11v, and 802.11r :
https://support.apple.com/en-au/HT202628 https://support.apple.com/en-au/HT202628
https://msdn.microsoft.com/en-us/library/windows/hardware/mt484190(v=vs.85).aspx https://msdn.microsoft.com/en-us/library/windows/hardware/mt484190(v=vs.85).aspx
Is there a list of Intel Wireless Adapters and their hardware support of these protocols?
It would be very helpful for Wireless Network Administrators!
Rowan
AShuk5
Thank you, Aleki,
I am still not clear what need to done, i have noticed an issue where product brief says 11k is supported and i dont see any RRM capabilities bit set, which means the support for 11k is not there with Intel chip-7265. To get this solved what do you want me to do.
Appreciate if u can clarify me what to be done would be of grt help to me. I dont have any prior experience beyond me testing. I am sure you can guide me
Asies
Asie,
We are going to check it and will get back to you as soon as possible.
let us know if you have any further questions.
Aleki
Asie,
Thank you for your time. Intel has recently released the driver package version 19.10.0 which contains a lot of fixes and improvements. For your convenience, here is the link to it: https://downloadcenter.intel.com/download/26240/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?product=83635 Intel® PROSet/Wireless Software and Drivers for Windows® 10 - Package Version: 19.10.0. The driver version for the Intel® Dual Band Wireless AC-7265 is the 18.33.3.2
Aleki
AShuk5
Thanks Aleki,
In one of the test system system having Fedora-25 with intel 7265, i was trying to create mutiple virtual wireless in managed mode, i was able to sucessfully create it using command "iw dev interface add type managed.
I could see the newly created virtual interface using iwconfig command
I can also able to connect using these virtual interface with AP.
But, only one remains active at any point of time,
Ex: i created three multi-vif (Vir-Sta1 , Vir-Sta2, Vir-Sta3)
I cannot conect all three virtual interface to some AP, at any point only one can be connected, and before connecting other i shut the link of first then only second will work)
Does that mean multi-vif with intel chipset is not supported or is it limited to one STA ?
Asies,
We understand you are performing a test on in Linux* environment, correct? We would like to inform you that any support for Linux* and its variants are obtained through this link: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005511.html?wapkw=linux+support+for+bluetooth Linux* Support for Intel® Wireless Adapters let us know if this piece of information helped you to find your answer.
Aleki
AShuk5
Hi Aleki,
I had already used the driver from provided link, thts how the Adapter came up and Linux was able to detect it,
My question is very specific to the intel chipset, which has nothing to do With Linux support.
Linux task was to create multiple subinterface he did it correctly, his task of connecting to AP he is doing correcltly
Now only one interface is connecting at any point is relevant with the chipset, I think the technical Word is mutiple - Vif support
Could u confirm me whether the intel chipset has the capability, can we have mutiple Wirless virtual STA and all are connected.
I dont think it has anything to do Linux, if it is then could u help me to get more info on this.
Asies,
Thank you for your clarification. For questions about Intel® Chipset and its capabilities, we advise to post your question directly in this respective community. Any other question about Intel® Wireless Adapters and their features and capabilities will be with us.
Here is the link to the chipset community: /community/tech/chipsets/content Chipset Community
Aleki
AShuk5
Thank you, appreciate the guidance given for next step
Thx
Asies
Asies,
You are very welcome. Let us know if you have any further questions in the future. We will be more than glad to assist you.
Aleki
