Wireless
8712 Discussions
Intel® Wireless Bluetooth for Windows 11 signature is out of date
Wayne12
Windows 11 is rejecting the driver signature for the Intel Bluetooth connection. Is there a work around? Does Intel know and is it trying to fix it?
From the Intel assistant:
  • Driver Details Up to date
  • Provider Intel Corporation
  • Version23.110.0.4
  • Date2024-12-18
From the Device manager:
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Windows cannot verify the digital signature for this file. The signing certificate for this file has been revoked.
RandyT_Intel
Hello Wayne12
I'm glad to hear that the issue with the error message has been resolved. Intel DSA may incorrectly show an update available even though the latest supported Intel Wireless Bluetooth driver is already installed. Please ignore the update message in Intel DSA, as you already have the latest driver. This issue will be addressed in a future release of Intel DSA.
Use your system as you normally would and monitor the performance of the WiFi and Bluetooth functionalities. If everything is working smoothly, it is likely that the issue has been resolved. The integration seems to have resolved the problem you were experiencing with IDSA.
If you still need version 23.110.0.5 of the Bluetooth driver, I can check our repository or archives. Sometimes, older or withdrawn versions are still available for download, but at the moment, I cannot see version 23.110.0.5 of the Bluetooth driver in our download center.
You may still provide the requested details if you want further assistance. However, if you do not need any additional help and the information provided is sufficient, please let me know so I can determine the next best course of action.
Randy T.
pmes
I've also run into this problem within the last few days!
Surendharan
I am having this issue to. the bluetooth under device manager shows error after updating to 23.110.0.4
23.100.0.4 works better.
Worst problem is it auto updates even when updating windows...I had to roll back every time
Wayne12
Yeah, that works but like you say, you have to rollback so it might have a security weakness, but it's unlikely. On the release notes for the latest version it said to disconnect and remove all the links to devices. Have you tried doing that? I was thinking of doing it but it's a lot of work and might not fix it for the next windows update.
Surendharan
Yes i removed /unpaired all Bluetooth devices and then updated, still same issue.
RandyT_Intel
Hi Wayne12
Thank you for reaching out to Intel Customer Support. To help us isolate and diagnose the issue you’re experiencing with your Wi-Fi/Bluetooth, I need to gather some additional information. Could you please provide answers to the following questions:
  1. Are you having issues with Wi-Fi, Bluetooth only, or both?
  2. When did it start to happen?
  3. Do you remember if this issue started after a new OS update or Wireless driver update?
  4. Have you tried rolling back to a previous driver version for testing?
  5. Have you installed any recent software or hardware in your system?
  6. Can you please run the System Support Utility (SSU) and share the logs with me?
  7. Could you provide screenshots of the issue or error message you encounter?
You may also try this step to follow in order to fix Error Code 39 on Intel® Wireless cards in Device manager.
When checking the Device Manager an error appears on the Intel® Wireless card making the Wireless connection unusable. The error message states: Windows cannot load the device-driver for this software. The driver may be corrupted or missing (Code: 39)
  1. Set BIOS settings to defaults
  2. Perform a clean Install of the wireless driver
  3. Perform all the available Windows updates
  4. Run the network troubleshooter in Windows®
  5. Re-install operating system
You can also check this article for additional information: Codes 10, 22, 28, 31, 43 or 45 Errors in Device Manager for...
Thank you for your cooperation. I look forward to your response.
Randy T.
Wayne12
Hi Randy,
I don't know whether you've seen the dialogue, but it's very clear it's a problem with the digital signature in the latest update which happened in January. I've already done all the checks you indicated including a clean install and checking that Windows is up to date and I'm surprised that you're asking me to do it again when I've clearly shown the problem when I raised the issue.
The Device manager is clearly indicating that the signing certificate has been revoked (see below).
  1. Are you having issues with Wi-Fi, Bluetooth only, or both? Bluetooth only
  2. When did it start to happen? After last Windows update in late Jan
  3. Do you remember if this issue started after a new OS update or Wireless driver update? Yes, see above
  4. Have you tried rolling back to a previous driver version for testing? Yes and it works (see image)
  5. Have you installed any recent software or hardware in your system? No
  6. Can you please run the System Support Utility (SSU) and share the logs with me? See attached
  7. Could you provide screenshots of the issue or error message you encounter? See attached
To be specific I have manually rolled back to the previous version and it fixed the problem, then I updated to the following version straight from the Intel website and it causes the problem to appear.
Intel® Wireless Bluetooth® Drivers for Windows® 10 and Windows 11*
Installation successful
2025-02-03 11:58 AM
Description:
Installs Intel® Wireless Bluetooth® version 23.100.1 Driver version varies depending on the wireless adapter installed.
Version:
23.100.0.4
Release date:
December 17, 2024
Size:
70.96 MB
See first 3 images
I rolled back again to 23.90.0 and it fixed the problem immediately. See the image.
RandyT_Intel
Hello Wayne12
To further investigate the issue you are experiencing, I kindly request some additional information. Please see the questions and instructions below:
  1. Logs indicate that you are using an ASRock B450 Pro4 desktop with an AMD chipset. Could you please confirm if you have self-integrated the AX200 module into this system?
  2. Regarding the Code 39 error via the Bluetooth driver version 23.110.0.4 from Windows Updates, we would appreciate it if you could collect the following logs:
  • setupapi.dev.log under C:\Windows\INF
  • WindowsUpdate.log : Open "Command Prompt" as Administrator, enter the command "Powershell Get-WindowsUpdateLog", then a new WindowsUpdate.log file will be automatically generated on the Desktop.
  1. Additionally, could you please provide a screenshot of the Device Manager showing the problematic driver version 23.110.0.4? Specifically, when the code 39 error occurs, click on the "Driver" tab to show version 23.110.0.4, and expand the "Network adapters" to show it's AX200. For your reference, please see the attached "Sample-DriverVersion.png".
Your cooperation in providing this information will greatly assist us in diagnosing and resolving the issue
Randy T.
Wayne12
Hi, again Randy.
Hmmm, I went to the Intel Driver and Support page again, to download version 23.110.0.4 and I saw there were new updates to the Wifi and the Bluetooth drivers, so I executed the updates. You can see from the screenshot, the AX200 is on 23.110.0.5 and dated 4th February and the bluetooth driver is on version 23.100.0.4 dated 3rd February.  I can't see a version 23.110.0.5 for the Bluetooth driver.
 And both drivers are fully up to date.
So I'm guessing that someone has withdrawn version 23.110.0.5 of the Bluetooth driver and updated the AX200 driver to integrate with version 23.100.1 of the Bluetooth driver, And it's now working.
Could you please confirm that I'm right and the problem has been solved or tell me where I can find v23.110.0.5 of the Bluetooth driver so I can do your checks listed above?
mikkelrev69
Hi.
DSA ha never listed any 23.110.0.4 driver yet. Latest is 23.100.1.1 and is signed and works fine.
The 23.110.0.4 package floating around 3rd party databases is most lighly corrupt with only 18 mb package vs. 28 mb which all previos versions were.
RandyT_Intel
Hello Wayne12
Randy T.
frnkgriffin
I just installed DSA and installed the new wifi driver package.  Problem still not fixed.  HP Omen.
mikkelrev69
...What do you mean by the "new"? 23.110.0.4 or even newer than that?
If you haven't already, try to roll back to the old 23.100.1.1 which works fine. It seems that the "new" 23.110.0.4 package is most lightly corrupt. (File size only 18 mb vs. 28 mb which all previous packages were)
mikestew
hello im using a dell Inspirion 7791 and both dell and intel software saying my drivers are up to date. But after checking device manager it shows original driver for my bluetooth from 6/2006 and i got this from last update...
Device BTH\MS_BTHPAN\6&746b4c7&0&2 was configured.
Driver Name: bthpan.inf
Driver Package ID: bthpan.inf_amd64_e5961f86fb449044
Class GUID: {4d36e972-e325-11ce-bfc1-08002be10318}
Driver Date: 06/21/2006
Driver Version: 10.0.26100.4061
Driver Provider: Microsoft
Driver Section: BthPan.Install
Driver Rank: 0xFF0000
Matching Device ID: BTH\MS_BTHPAN
Outranked Drivers:
Device Updated: false
Parent Device: USB\VID_8087&PID_0026\5&d02ab13&0&10
I just downloaded newest intel bluetooth driver 7/22/2025 so why has my system using intel driver support showing successful?
Everything seems to work, i just unlinked my phone and tried troubleshooting but still the 2006 driver is still shown. I understand my pc is older, but it runs great. I just want to keep all my drivers updated and planning to get fiber with 2g but now with this issue of my bluetooth not updating has me also worried that my intel wifi6 ax201 which is also not updated to the lastest version would cause me not to get full speeds. I also will attach wifi download file showing it didnt update..
Device PCI\VEN_8086&DEV_02F0&SUBSYS_40708086&REV_00\3&11583659&0&A3 was configured.
Driver Name: oem155.inf
Driver Package ID: netwtw08.inf_amd64_f8921816e8b82c26
Driver Date: 05/02/2025
Driver Version: 23.140.0.3
Driver Provider: Intel
Driver Section: Install_GEN_QSR_HrP2_201_AX_2x2_WinT
Driver Rank: 0xFC0001
Matching Device ID: PCI\VEN_8086&DEV_02F0&SUBSYS_40708086
Outranked Drivers: netwtw10.inf:PCI\VEN_8086&DEV_02F0&SUBSYS_40708086:00FF1001 oem31.inf:PCI\VEN_8086&DEV_02F0&SUBSYS_40708086:00FC0001 oem100.inf:PCI\VEN_8086&DEV_02F0&SUBSYS_40708086:00FC0001
Parent Device: ACPI\PNP0A08\0
If you can please help me figure out why i cannot get them to update using intel's update software, I be greatly appreciative
RandyT_Intel
Hello Wayne12
As the problem has been addressed, I will now proceed with closing this ticket. Should you encounter any further issues in the future, please feel free to contact us again here or submit a new ticket, as this case will no longer be monitored.
I wanted to share with you about the latest updates regarding the drivers for your AX200 device. The latest generic Wi-Fi driver available is version 23.110.0.5. As for the Bluetooth driver, it remains the same as the previous package, version 23.100.1, which was released on December 17, 2024.
For your convenience, here is the link to download the latest Bluetooth driver: Download Software and Drivers for Intel® Wireless Bluetooth®
Randy T.
mikkelrev69
Hello.
I'm new to this forum and landed here because I searched for this very same driver.
I'm on 23.100.0.4 which works fine. IDSA do not list the 23.110.0.4 as available update, but I wondered why intel Bluetooth didn't update at the same time as Wifi driver did as it usually does.
My 3rd. party driver software "Driver Fusion" listed the new 23.110.0.4 bluetooth driver though as available update, and when I searched the same database online I noticed a BIG difference between the new and previous driver package file sizes. All previous (to the extent of the 6-7 latest packages I bothered to check) file sizes were 28 mg. The 23.110.0.4 is only 18 mb. So the file has to be corrupt or missing vital parts.
