Community
cancel
Showing results for
Search instead for
Did you mean:
GKova2
Intel centrino N 6235 Windows 10 Wifi Driver
Jump to solution
Hi All,
is there an updated Wifi Driver available for the N 6235 card?
In downloads section I can't find any drivers for win10. I know that Win10 has some built-in driver for this card (version 15.x), but I'm not sure whether the connection loss problem is solved in that version:
Is there any chance to get the new 17.x or 18.x drivers for Windows 10?
Thanks!
kogabe
ASouz7
Kogabe,
As you know, the support for the Intel® Centrino® Advanced-N 6235 is provided by Windows*10 own inbox driver version (15.16.0.2). However, the latest available drivers in our download center for this adapter is Windows 8.1* compliant and should work with Windows*10. For your convenience here is the link to the drivers: https://downloadcenter.intel.com/download/25276/Intel-PROSet-Wireless-Software-for-Windows-8-1- Intel® PROSet/Wireless Software for Windows 8.1*
For the time being, it is the option available and unfortunately there are no information if there will be any change in the future. We recommend to always contact your computer manufaturer to see if they have any solution availbale on their side. Here is a link for the computer manufacturer form of contact: http://www.intel.com/support/oems.htm Computer Manufacturer Support
ASouz7
Kogabe,
GKova2
Hi aleki_intel,
thanks for your fast reply! I had no idea that Win8.1 drivers could work with Win10, so I did not try earlier
I have changed the Windows stock driver to Intel version 18.20 and it seems that my wireless connection is stable now.
Thanks for your help!
kogabe
USeif
hello
I updated my samsung smart pc with the 6235 wifi module to win 10. but with the ms-own driver the widfi-adapter often could'nt be started, so the adapter didn't showed up in device manager. sometimesca restart helped.
after trying older drivers, now I found the one which works fine for me with win10: Version 15.10.5.1 from 2013
