Wireless
8661 Discussions
Intel dual ban AC7260 vs Intel wifi1000 BGN
TMosc
I have an Asus 302L laptop which has an Intel dual band AC7260 wireless adapter. Also have an ASUS RT-N66U Dual-Band Wireless-N900 Gigabit Router. My husband has an HP laptop with an Intel wifi Link 1000 BGN wireless adapter. Running speedtest side by side in the room, His measures 82Mbps mine 24. I have the latest intel driver 17.16.0.4 I have tried some of the tweaks on this forum. Nothing is speeding mine up. Any suggestions?
ASouz7
Hello Lcangler,
When running speed tests, it is important to stop all processes, sites, programs...etc that could be use internet in the background in order to get better results. However, here are some tips that can help you improve your experience with our Intel® Dual Band Wireless-AC 7260. Additionally, please check these links below as they may contain information that can also help you improve your connection.
http://www.intel.com/support/wireless/wlan/sb/CS-025332.htm Intel® Wi-Fi Products — Resolving Wi-Fi Network Connection Issues
http://www.intel.com/support/wireless/wlan/sb/cs-006205.htm Intel® Wi-Fi Products — Power Save Polling (PSP) Causes Connection Issues with Access Points
http://www.intel.com/support/wireless/wlan/sb/CS-031509.htm Intel® Wi-Fi Products — Possible Interference by Other Wireless Devices May Impact 802.11n Performance
http://www.intel.com/support/wireless/wlan/sb/CS-034875.htm Intel® Wi-Fi Products — TechNote: Access Point Interoperability Issue with uAPSD
http://www.intel.com/support/wireless/wlan/sb/CS-030282.htm Intel® Wi-Fi Products — Why am I Not Able to Connect at 300 Mbps with My 802.11n Device?
http://www.intel.com/support/wireless/sb/CS-029893.htm Wireless Networking — Frequently Asked Questions - Wi-Fi
1 - Turn off Bluetooth if not necessary as it uses the same antennas used by WiFi and consequently causing impact to your connection.
2 - Turning off the power saving related functions may help preventing unexpected disconnections, sudden connections speed drops issue and keeping the adapter working at its maximum performance. Please follow the steps below:
3 - Set the Power Savings settings - Go to Control Panel >> Hardware and Sound >> Power Options >> Set to High Performance and apply it to default settings.
4 - You may check the Change Plan Settings >> Change Advanced Power Settings >> Wireless Adapter Setting >> Power Saving Mode and make sure both on battery and plugged in are set to Maximum Performance as shown in the picture below. *Please note that this picture is merely illustrative and may differ from the configurations of your computer.
/servlet/JiveServlet/showImage/2-312713-245127/pastedImage_0.png
5 - Set the advanced settings of the adapter:
  • Go to Device Manager >> Network Adapters >> Intel(R) Dual Band Wireless-AC7260, right click on it and select properties.
/servlet/JiveServlet/showImage/2-312713-245128/pastedImage_3.png
  • Select Advanced page to set the value of U-APSD support to Disabled. *Find more details about U-SPSD by clicking here: http://www.intel.com/support/wireless/wlan/sb/CS-034875.htm Intel® Wi-Fi Products — TechNote: Access Point Interoperability Issue with uAPSD
  • Check the value of Transmit Power and make sure it is set to 5. Highest.
/servlet/JiveServlet/showImage/2-312713-245129/pastedImage_8.png
We do hope this information helped you resolve the issue.
