The 6 GHz band isn't showing for the Wi-Fi 6E AX211. I already asked a question, but I took too long to respond and the thread was closed. To answer the previous thread's questions:
- 6 GHz is allowed in Canada on the following spectrum
- The manufacturer supports 6 GHz
- The router supports 6 GHz
- The latest driver is installed
- The latest version of Windows is installed (Windows 11 Version 24H2 Build 26100.4061)
I'm out of ideas. Is there anything else I can try?
Shane.
Hello SGoodman,
Thank you for posting back in Intel Communities.
We usually follow up on thread before we close it. I understand that your system met all the requirement to be able to connect to 6 GHz channels.
Please proceed with a clean installation of the latest OEM driver, version 23.40.0.4. Please also check the Recommended Settings for 802.11ax Connectivity.
I hope this helps.
JeanetteC.
Hello SGoodman,
Did you have a chance to review the previous post? Please feel free to reach out if you have any questions. Thank you.
Archie D.
Hello SGoodman,
We have not heard back from you so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
