Wireless
8547 Discussions
Is 6 GHz disabled?
SGoodman
The 6 GHz band isn't showing for the Wi-Fi 6E AX211. I already asked a question, but I took too long to respond and the thread was closed. To answer the previous thread's questions:
I'm out of ideas. Is there anything else I can try?
Shane.
JeanetteC_Intel
Hello SGoodman,
Thank you for posting back in Intel Communities.
We usually follow up on thread before we close it. I understand that your system met all the requirement to be able to connect to 6 GHz channels.
Please proceed with a clean installation of the latest OEM driver, version 23.40.0.4. Please also check the Recommended Settings for 802.11ax Connectivity.
I hope this helps.
JeanetteC.
ArchieD_Intel
Hello SGoodman,
Did you have a chance to review the previous post? Please feel free to reach out if you have any questions. Thank you.
Archie D.
JedG_Intel
Hello SGoodman,
We have not heard back from you so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
