Wireless
7111 Discussions
Is AC-8260 wireless card compatible with 802.11r features.
OOliv1
I have some roaming issues with my laptops (windows 10 laptops with Intel AC-8260 - driver 18.0.40.9). I will connect them using 802.11r features. Is it possible? Wireless infrastructure is Cisco Wireless Lan Controllers. Thanks
OlivierWifi,
The Intel® Dual Band Wireless-AC 8260 is compatible with protocol 802.11r. Could you please be so kind and let us know what exactly is the situation you are experiencing?
OOliv1
I tried to activate Fast BSS Transition on my Wireless controller but the client shouldn't associate correctly. Here are resume of debugs from my wlc :
  1. Association received from mobile on BSSID
  2. Marking this mobile as TGr capable
  3. Processing RSN IE type 48, length 22 for mobile
  4. Sending assoc-resp with status 43 (invalid AKMP)
  5. Including FT Mobility Domain IE (length 5) in Initial assoc Resp to mobile
  6. Sending Assoc Response to station on BSSID 04:da:d2:8b:a9:99 (status 43)
  7. Scheduling deletion of Mobile Station
  8. Deleting mobile on AP
Something to do at client side?
Thanks and regards
OlivierWiFi,
Thank you for the information, we are going to check these details and will advise soon. In the meantime, please let us know if you have more questions.
OlivierWiFi,
The Intel® Dual Band Wireless-AC 8260 supports 802.11r on Windows® 10 when the recommended driver from the Computer manufacturer is used, as second option, you can try the Generic version of Intel® PROSet/Wireless Software and Drivers for Windows® 10 found in this link: https://downloadcenter.intel.com/download/25833/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?product=86068 Intel® PROSet/Wireless Software and Drivers for Windows® 10 - Version: 18.40.0
Please, review this documentation from Cisco* that has configuration details, you may also find the restrictions for 802.11r Fast Transition to make sure your system complies with Cisco* requirements: http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_01001101.html Cisco Wireless Controller Configuration Guide, Release 8.0
Please note that Pre-Shared Key (PSK) and Open Networks are currently not supported with 802.11r in Windows® 10. You may check the following link from Microsoft* for details: https://msdn.microsoft.com/en-us/library/windows/hardware/mt484190(v=vs.85).aspx Fast Roaming with 802.11k, 802.11v, and 802.11r
OlivierWiFi,
We haven;t heard from you in a while so we would like to know if you still need our assistance regarding the compatibility with 802.11r with the The Intel® Dual Band Wireless-AC 8260. Please let us know as soon as you can.
OOliv1
Apparently, my system complies with Cisco requirements. I asked Cisco about my problems but any answers.
At this time, I can't connect the laptop to my Wireless infrastructure using 802.11r. Driver is 18.40.0.
I see the following 802.11i status code :
43 (802.11i) Authentication and Key Management Protocol (AKMP) not valid
OlivierWiFi,
We are going to check this and will advise as soon as we can. In the meantime, please feel free to ask any questions or add any other piece of information you deem relevant.
OlivierWiFi,
Thank you for your time. In order to help you better, we need some more information. Did you create a service ticket with Cisco*? If so, please let us know the number of it and its content.
Pleasem run this tool: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility in order to obtain the logs. If there is information about any possible error messages, please let us know. If possible, send us screenshots or pictures.
*NOTE: All the information requested above you may send us privataly. We are going to send you an email so you can reply back with that information. Please check your email inbox and confirm that you have received our email.
ychen97
Maybe it is not right place to ask question.
How about AC7265 card? Does that card support 802.11r under Windows 10?
John@2000,
We are more than glad to answer your question. Yes, the Intel® Dual Band Wireless-AC 7265 supports 802.11r. Please check this document online for further information:http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000021562.html Windows® 10 and Supported Intel® Wireless Adapter Protocols
Best regard,
Aleki
AShuk5
Looks Like Oliver and me are sitting in the same Boat, doing the same test, the only difference is i am using Intel 7265.
All helps are appreciated, to narrow down the root cause, let it be at any side, i can drive this if it belongs to Cisco software FT side bugs
Thx
Asies
AShuk5
Team,
Its in the interest of both Cisco and Intel both to get resolved, due to marketing reason, Could some body help here
Thx
Asies Shukla
Cisco System
Hello Asies,
Please make sure you are using https://downloadcenter.intel.com/download/26171/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?product=83635 Intel® PROSet/Wireless Software and Drivers for Windows® 10 [19.1.0].
Let us know if the issue persists, as we would need additional information to troubleshoot this further.
BStam
I'm using the AC-7260 on Windows 10. Just upgraded to the most recent drivers (listed above) 19.1.0. Took my card driver to 18.33.3.2 released 5/16. In my controller I'm still not seeing this supporting 802.11r:
In the show client detail I see:
Client Capabilities:
CF Pollable................................ Not implemented
CF Poll Request............................ Not implemented
Short Preamble............................. Not implemented
PBCC....................................... Not implemented
Channel Agility............................ Not implemented
Listen Interval............................ 225
Fast BSS Transition........................ Not implemented
11v BSS Transition......................... Not implemented
When I look at my iPhone I see:
Short Preamble............................. Implemented
Listen Interval............................ 20
Fast BSS Transition........................ Implemented
Folowed by some detail about it:
Fast BSS Transition Details:
Reassociation Timeout...................... 20
Total Preauth APs.......................... 0
When I look at my Android phone:
Listen Interval............................ 10
11v BSS Transition......................... Implemented
Followed by some detail about it:
Total Preauth APs.......................... 3
Preauth AP................................. 5c:83:8f:b8:63:cf
Preauth AP................................. 5c:83:8f:b8:5e:6f
Preauth AP................................. 5c:83:8f:b8:63:c0
So either the AC-7260 doesn't support 802.11r or there is still some issue with the driver?
AShuk5
Intel Team,
As said earliear, I am using Latest driver 19.1 and chipset is Intel 7265, Its not connecting . FT is enabled on wlan, In assoc phase itself it fails
Hello Asies,
Please provide any logs or events showing the issue, along with additional information about the system and the environment that can help us get a better idea of your case.
Bstamper, thank you for the input, as you confirmed, the 7260 series adapters do not support 802.11r.
Jonathan
AShuk5
What logs u would be looking, Air traces,? or is there any tool available from intel to collect all the logs and then i can attach.
Thank you for responding.
Asies
Hello Asies,
We would like to inform that the new version of https://downloadcenter.intel.com/download/26214/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?product=86068 Intel® PROSet/Wireless Software and Drivers for Windows® 10 [19.2.0] has been released.
Please proceed to apply the update and let us know if there is any change in the behavior.
We haven't received any updates recently. Let us know if there was any improvement after applying the new driver.
