Wireless
8317 Discussions
Issue with BE200 WiFi Card Bluetooth Detection on Dell Latitude 3420
Harisankar1601
Dear Intel Support,
I have installed the BE200 WiFi card on my Dell Latitude 3420 laptop, which is running Ubuntu 24.04 LTS. The WiFi functionality is working correctly, as confirmed by the "lspci" command. However, I am facing an issue with the Bluetooth functionality. Despite the WiFi being detected, there is no sign of the Bluetooth device when I run the “bluetoothctl list” command.
Could you please provide guidance on how to resolve this issue? Additionally, if there are any specific drivers or firmware updates required for the Bluetooth functionality of the BE200 card, kindly share the necessary details.
Thank you for your assistance.
Hari Sankar
Mike_Intel
Hello Harisankar1601,
  1. Just to confirm, you upgraded the wireless controller of your system?
  2. Who installed the BE200?
  3. Can you share the link of the driver that you used?
Michael L.
Harisankar1601
Hi Mike_Intel,
Please find the steps followed to install the module,
Downloaded the latest kernel https://bugs.launchpad.net/ubuntu/+source/linux/6.8.0-11.11
 and used dpkg tool to install it.
After rebooting, navigated to Advanced options for Ubuntu and Selected the kernel version 6.8.0-11-generic from the list.
Hari Sankar
Mike_Intel
Thank you for the quick reply.
Can you also confirm if you upgraded the wireless card to BE200? If yes, who installed the card on your system?
Michael L.
Harisankar1601
Hi Mikke_Intel,
Yes, We have upgraded the Wireless card to BE200, installation was done by our in-house IT team.
Mike_Intel
If you updated the Wireless card, you need to consult the manufacturer of the board or system first to check if it is compatible and if there are needed settings or configuration. Please check the link below for the Regulatory in upgrading the Wireless controller.
https://www.intel.com/content/www/us/en/support/articles/000005687/wireless.html
Michael L.
Mike_Intel
Michael L.
Harisankar1601
Hi Mike_Intel,
Yes, We are checking with the board vendor.
We have a another query on the subject.
We wanted to know is it possible to interface the BT function though PCIe along with WIFI instead of using USB in the M.2 due to limited availability of USB ports. if so is it possible through Linux driver update?
Harisankar
NormanS_Intel
Thank you for your response. I recommend installing the latest stable version of the mainline kernel, 6.9, from kernel.org, which includes the latest wireless firmware for the Intel BE200, version 89.
Regarding the interface, I will discuss the possibility of having the BT functions through PCIe along with WiFi instead of using USB in the M.2 slot internally. I will provide an update in this post once more information is available.
Norman S.
NormanS_Intel
We have reviewed your issue and would like to inform you that the latest stable version of the mainline kernel, 6.10, from kernel.org, includes the most recent wireless firmware for the Intel BE200, version 90, updated on August 5th.
The Intel® Wi-Fi 7 BE200 System Interface is Type M.2: PCIe*, USB. For more details, you can visit this link: https://ark.intel.com/content/www/us/en/ark/products/230078/intel-wi-fi-7-be200.html
Additionally, we recommend consulting with your laptop manufacturer before installing or changing the Intel® Wireless Adapter in your system. It is essential to contact your system manufacturer to ensure that the Intel® Wireless Adapter you plan to install is approved for use in your system and country. The manufacturer may have made alterations, customizations, or other changes to the software or hardware packaging they provide.
If you need further assistance, let us know.
Norman S.
NormanS_Intel
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Norman S.
