Hi Team,
We’ve connected the Intel BE200 module to the NXP LA1224 reference board using a PCIe M.2 connector. Below are the kernel configurations ,
/*intel wifi driver */
CONFIG_IWLWIFI=y
CONFIG_IWLWIFI_LEDS=y
CONFIG_IWLDVM=y
CONFIG_IWLMVM=y
CONFIG_CFG80211=y
CONFIG_MAC80211=y
CONFIG_RFKILL=y
CONFIG_PCI=y
CONFIG_PCI_DOMAINS=y
CONFIG_PCI_DOMAINS_GENERIC=y
CONFIG_PCI_SYSCALL=y
CONFIG_PCIEPORTBUS=y
CONFIG_HOTPLUG_PCI_PCIE=y
CONFIG_PCIEAER=y
CONFIG_PCI_LABEL=y
CONFIG_PCIE_BUS_DEFAULT=y
CONFIG_PCI_ENDPOINT=y
CONFIG_PCI_ENDPOINT_CONFIGFS=y
/* Bluetooth drivers*/ CONFIG_BT=y
CONFIG_BT_BREDR=y
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=y
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_LEDS=y
CONFIG_BT_DEBUGFS=y
CONFIG_BT_INTEL=y
CONFIG_BT_BCM=y
CONFIG_BT_HCIBTUSB=y
we can detect the Wi-Fi module via lspci.However, the Bluetooth module isn't detected using lsusb.
We're using the Layerscape SDK, which supports kernel version 5.10, and have placed the firmware in /lib/firmware.
Could you please guide us in troubleshooting this issue or suggest any additional steps for BT detection?
Hi Anitha_K,
Thank you for posting in the Community!
I would like to clarify some things first:
What is the symptom of the issue?
Are you having issues on WiFi or Bluetooth or both?
When did it start to happen?
Do you remember if this issue happened after a new OS update or Wireless driver update?
Have tried a roll back to a previous driver version for testing?
What steps do you take to reproduce your issue?
Were you able to have wireless connection in a normal/expected performance before?
Have you installed any recent software or hardware in your system?
Dean R.
Hi Anitha_K,
Dean R.
Hi Anitha_K,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
Hi Anitha_K,
To confirm compatibility, please contact the board manufacturer. You can reach NXP support through their website: NXP Support
Additionally, please review our article on Regulatory Information Regarding Wireless Hardware Installation or Upgrade.
Once again, I will be closing this inquiry and no longer be monitored.
Dean R.
