Wireless
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
7299 Discussions
Killer Networking on Windows 10 drops wireless signal. How to get wireless drivers from intel?
I've got an intel board with a Killer Wireless component built in. The wi-fi keeps dropping. I know I can replace the drivers from Killer with the most up-to-date driver that will work with this board. Problem is, I don't know where to get it. Can anyone help?
Here is my wireless card info
SSID:CMT_PUBLICProtocol:802.11gSecurity type:OpenNetwork band:2.4 GHzNetwork channel:6IPv4 address:192.168.2.148Manufacturer:Qualcomm Atheros Communications Inc.Description:Killer Wireless-n/a/ac 1535 Wireless Network AdapterDriver version:12.0.0.285
And system specs
OS NameMicrosoft Windows 10 HomeVersion10.0.14393 Build 14393Other OS DescriptionNot AvailableOS ManufacturerMicrosoft CorporationSystem NameLAPTOP-U488IHRJSystem ManufacturerRazerSystem ModelBlade StealthSystem Typex64-based PCSystem SKURZ09-01682E22ProcessorIntel(R) Core(TM) i7-6500U CPU @ 2.50GHz, 2592 Mhz, 2 Core(s), 4 Logical Processor(s)BIOS Version/DateAmerican Megatrends Inc. 5.11, 12/30/2015SMBIOS Version3.0Embedded Controller Version255.255BIOS ModeUEFIBaseBoard ManufacturerINTEL CorporationBaseBoard ModelNot AvailableBaseBoard NameBase BoardPlatform RoleMobileSecure Boot StateOnPCR7 ConfigurationElevation Required to ViewWindows DirectoryC:\WINDOWSSystem DirectoryC:\WINDOWS\system32Boot Device\Device\HarddiskVolume2LocaleUnited StatesHardware Abstraction LayerVersion = "10.0.14393.206"User NameLAPTOP-U488IHRJ\kelsaTime ZonePacific Standard TimeInstalled Physical Memory (RAM)8.00 GBTotal Physical Memory7.89 GBAvailable Physical Memory2.72 GBTotal Virtual Memory9.58 GBAvailable Virtual Memory2.95 GBPage File Space1.69 GBPage FileC:\pagefile.sysHyper-V - VM Monitor Mode ExtensionsYesHyper-V - Second Level Address Translation ExtensionsYesHyper-V - Virtualization Enabled in FirmwareYesHyper-V - Data Execution ProtectionYes
Hello kwangpo,
We understand you have a Razer* Blade Stealth* laptop which uses an Intel® Board and a Killer* Wireless Adapter, for which you would like to find the latest wireless drivers available.
Unfortunately, we do not have these drivers available, as your adapter is not an Intel® product, but rather a third-party M.2 component added onto your system. For driver support, we can recommend contacting your computer manufacturer/OEM (https://www.razerzone.com/ Razer*), or your wireless adapter manufacturer (http://www.killernetworking.com/ Killer Networking*). As an extra mile, we have located the support and downloads page for your laptop:
- http://www.razersupport.com/gaming-systems/razer-blade-stealth-6500u/ Razer* Blade Stealth* 12.5" (2016) - Intel® 6500U Support & Downloads.
NOTE: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.
Carlos A.
