Wireless
8781 Discussions
Killer Networking on Windows 10 drops wireless signal. How to get wireless drivers from intel?
I've got an intel board with a Killer Wireless component built in. The wi-fi keeps dropping. I know I can replace the drivers from Killer with the most up-to-date driver that will work with this board. Problem is, I don't know where to get it. Can anyone help?
Here is my wireless card info
SSID:CMT_PUBLICProtocol:802.11gSecurity type:OpenNetwork band:2.4 GHzNetwork channel:6IPv4 address:192.168.2.148Manufacturer:Qualcomm Atheros Communications Inc.Description:Killer Wireless-n/a/ac 1535 Wireless Network AdapterDriver version:12.0.0.285
And system specs
OS NameMicrosoft Windows 10 HomeVersion10.0.14393 Build 14393Other OS DescriptionNot AvailableOS ManufacturerMicrosoft CorporationSystem NameLAPTOP-U488IHRJSystem ManufacturerRazerSystem ModelBlade StealthSystem Typex64-based PCSystem SKURZ09-01682E22ProcessorIntel(R) Core(TM) i7-6500U CPU @ 2.50GHz, 2592 Mhz, 2 Core(s), 4 Logical Processor(s)BIOS Version/DateAmerican Megatrends Inc. 5.11, 12/30/2015SMBIOS Version3.0Embedded Controller Version255.255BIOS ModeUEFIBaseBoard ManufacturerINTEL CorporationBaseBoard ModelNot AvailableBaseBoard NameBase BoardPlatform RoleMobileSecure Boot StateOnPCR7 ConfigurationElevation Required to ViewWindows DirectoryC:\WINDOWSSystem DirectoryC:\WINDOWS\system32Boot Device\Device\HarddiskVolume2LocaleUnited StatesHardware Abstraction LayerVersion = "10.0.14393.206"User NameLAPTOP-U488IHRJ\kelsaTime ZonePacific Standard TimeInstalled Physical Memory (RAM)8.00 GBTotal Physical Memory7.89 GBAvailable Physical Memory2.72 GBTotal Virtual Memory9.58 GBAvailable Virtual Memory2.95 GBPage File Space1.69 GBPage FileC:\pagefile.sysHyper-V - VM Monitor Mode ExtensionsYesHyper-V - Second Level Address Translation ExtensionsYesHyper-V - Virtualization Enabled in FirmwareYesHyper-V - Data Execution ProtectionYes
Hello kwangpo,
We understand you have a Razer* Blade Stealth* laptop which uses an Intel® Board and a Killer* Wireless Adapter, for which you would like to find the latest wireless drivers available.
Unfortunately, we do not have these drivers available, as your adapter is not an Intel® product, but rather a third-party M.2 component added onto your system. For driver support, we can recommend contacting your computer manufacturer/OEM (https://www.razerzone.com/ Razer*), or your wireless adapter manufacturer (http://www.killernetworking.com/ Killer Networking*). As an extra mile, we have located the support and downloads page for your laptop:
- http://www.razersupport.com/gaming-systems/razer-blade-stealth-6500u/ Razer* Blade Stealth* 12.5" (2016) - Intel® 6500U Support & Downloads.
NOTE: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.
Carlos A.
