Wireless
8711 Discussions
Latest Wireless Driver for AC 2760
kengtaan
I understand Intel no longer support AC 2760. I am currently running version 18.33.7.2 which does not support wifi 6.
Does someone have the latest / last version of the AC 2760 driver ?
n_scott_pearson
I presume you are referring to the Wireless-AC 7260. I am sending you a Private Message regarding access to the last driver packages. With respect to WiFi6, sorry, but this card is only capable of supporting WiFi5. You need a Wireless-AX card before you will start to see support for WiFi6/WiFi6e.
kengtaan
Thanks Scott.
Yes, I am referring to Wifi AC 7260. I have followed your download link in your private message and it worked.
My laptop is now able to detect the SSID of my new Wifi 6 router and able to connect successfully.
Thanks a lot,
Keng Taan
pc123
Hi Scott,
Can you please send me the last driver packages as well?
pc123
Hi Scott,
n_scott_pearson
I sent you a Private Message (PM). Check your PM Inbox.
...s
Jatt
Hi Scott,
Can you please send me the last driver packages for the ac7260 as well?
n_scott_pearson
Sometime before your posts, I abandoned my crude method of tracking downloads and made the pertinent portion of my archive available in a OneDrive share. Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access this share. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
Jatt
