Wireless
7587 Discussions
Latest driver for intel dual band wireless-n 7260 Win 10 64bit
ckrause
I´m looking for the latest driver for the Intel dual band wireless-n 7260 for Windows 10 64bit. The official support pages are not available (404). It would be very nice if anyone could tell me a download link. (f.e. url )
Thanks and best regards,
Christian
n_scott_pearson
Check your Private messages.
n_scott_pearson
Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
maurice2463
Hi Scott. Can I also get the latest win10 drivers for the AC7260 for wifi6? Much appreciated. Thanks
n_scott_pearson
Hope this helps,
gad95
Hello Scott,
Thank you for supplying the link.  Downloading and installing the Win10 Wireless driver from your archive has solved an intermittent WiFi connectivity problem introduced to my personal laptop about a year ago and plaguing me ever since. I really appreciate your altruistic support. If ever you are in the UK I'll buy you a pint!
Here's my problem/fix data in case it helps anyone else:
System detail:-
Device name: HP EliteBook 840 G1
System type: 64-bit operating system, x64-based processor
Edition Windows: 10 Pro Version 22H2
Intel Dual Band Wireless-N 7260 detail:-
Problematic Driver Version: 18.33.14.3
Updated (fixed) Driver Version: 18.33.17.1
Fix detail:-
Download and run WiFi_21.10.1_64_Win10.exe application file (Intel PROSet/Wireless SEStub Setup Program)
Application file size: 181MB
usehev
i also need 7260 drivers thanks man you really helped me
Dylan95
I also need Intel dual band wireless-n 7260 for Windows 10 64bit, Thanks~
Pawelo
Hi Scott,
Can I get a link to this driver please. Thanks.
n_scott_pearson
@Pawelo,
Hope this helps,
iamsid
I also need this driver for Win10 64bit...please
Jacuniol
kindly asking for latest driver for intel dual band wireless n7260 to solve wifi6 issue.
Noviceuser
Hello please send the driver to me as well
GrumpyOG
I have a broken M6800 Wifi and need the AC7260 driver ... can you help please?
BarryC
I have just updated from coaxial cable to fiber (Optimum WifI 6e). My laptop Dell XPS 12 9Q33 now cannot see the new network. I have an Intel AC7260 wireless card running 18.20.0.9 from 8/23/15. Intel's site shows the below driver
  • Windows 11*, Windows 10, 64-bit*
  • Size: 38.6 MB
  • SHA1: 7C782AF71080EBC9C633284F89F98598459D824
but when I try to run it, it says it is incompatible with my system. Is there another one that I can be sent so the laptop can see my network?
69TransAm
First, if the laptop worked before, this doesn't sound like a laptop issue unless there was some change. E.g. I suspect mine went corrupt with a Windows update. I would engage the Internet Vendor's support before I started making changes to the laptop.
That said, a few basics...
> Assume your laptop is either W10 or W11 and 64bit - otherwise find a matching driver.
> Assume SSID & Password has been set by you on the new network router and it is broadcasting - verify with a mobile phone or other device, otherwise get internet vendor support.
I found 3 downloads for Driver installer tools on the Intel site, I would try them all. Following Scott's directions explicitly, all went well for me on the first driver try.
Below has some of the Inter Driver installs...
Intel® PROSet/Wireless Software and Drivers for IT Admins
...in case this doesn't allow hyperlinks...add www. at the beginning of the below and paste into your browser.
intel.com/content/www/us/en/download/18231/intel-proset-wireless-software-and-drivers-for-it-admins.html?product=94150
n_scott_pearson
You need the 18.33.17.1 version of the driver, found in the 21.10.1 package (final for these adapters), in order to correct the WiFi6 incompatibility. This package is not being hosted by Intel any longer. I have this package in my archive, however.
Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T in order to access my archive. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Hope this helps,
FredBR
Hi!
Would you please send me the  Intel® Dual Band Wireless-N 7260 driver?
Thanks!
M0ustafa
Jamorosi1112
I also need these drivers please, thank you!
Vin2004
Dear n_scott,
Please send me the Intel(R) Dual Band Wireless-AC 7260 latest driver for Win 10,64bit
Cavo
I´m looking for the latest driver for the Intel dual band wireless-n 7260 for Windows 10 64bit.Please send solution.
arrrcache
@Cavo :
The solution is to read any of the posts on the last page of this thread.
This is the latest post:
https://community.intel.com/t5/Wireless/Latest-driver-for-intel-dual-band-wireless-n-7260-Win-10-64bit/m-p/1576519/highlight/true#M52752
But there are also at least 11x more posts since November 2023 with the same download link just on the last page of this thread alone.
