Wireless
8782 Discussions
Linux / error: iwlwifi 0000:04:00.0: WRT: Invalid buffer destination
mattrattus
Recently there was a similar topic here, unfortunately it was closed because the author stopped writing back.
I decided to open a new one - in order to solve this problem from start to finish.
This error appeared after installing a new WiFi card.
So here goes...
Summary: Invalid buffer destination in iwlwifi during startup
Description:
The following iwlwifi error message appears during startup:
kernel: iwlwifi 0000:04:00.0: WRT: Invalid buffer destination
System Information:
- Distribution: Arch Linux
- kernel: 6.10.0-arch1-2
- Firmware Version: linux-firmware-20240703.e94a2a3b-1
- Wireless Hardware: Intel Corporation Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2
Additional Information:
This message does not affect wireless functionality but should be reviewed.
This error appears 3 times right after system startup.
I checked the LTE kernel - no change.
I will be more than happy to answer any additional questions.
SJohn_Intel
Hello Mattrattus
Thank you for the information and effort you have already put into addressing the issue. I appreciate your detailed input.
Upon reviewing your case and the issue you are experiencing; I need to request additional information to further validate and assess the problem. To ensure we are doing our best to provide support and determine the next steps.
Could you please provide the following details:
  1. What is the model of your computer?
  2. Is this a prebuilt or custom-built system?
  3. What other troubleshooting steps have you already tried?
  4. If applicable, what was the model of your previous Wi-Fi card?
This information will help us provide a resolution and determine the appropriate next steps.
John Craig S.
mattrattus
Hi Norman and John,
Thanks guys for your interest in my problem.
I've written back on each point below.
1. Lenovo ThinkPad T470
2. Computer is original, I just changed the WiFi card to a newer one - the one with the problem. Unless you are asking about the OS? It is Arch Linux built on the latest kernel. The last update to 6.10.2 didn't change anything.
3 I changed the kernel to LTS = didn't do anything
4. I changed from Intel Dual Band Wireless-AC 8260 - on it there was no such problem
Matt
NormanS_Intel
Hello Mattrattus,
I wanted to check if you had the chance to review the questions we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Norman S.
JeanetteC_Intel
Hello mattrattus,
Greetings.
This has been confirmed by our engineers. Kindly check the product specification for the supported wireless modules and Windows OS only for this Lenovo ThinkPad T470. I highly recommend contacting your system manufacturer support team to confirm the hardware incompatibility and/or Linux Distro the error of WRT: Invalid buffer destination might be due to a compatibility issue.
Reference article:
Regulatory Information Regarding Wireless Hardware Installation or Upgrade
JeanetteC.
JeanetteC_Intel
Hello mattrattus,
Greetings.
Reference article:
JeanetteC.
mattrattus
As I mentioned in the first post, this thread may also be useful to others.
The issue has been resolved positively. Not with the help of this forum, but as always - the development of the Linux kernel itself.
After updating to 6.11.1, this problem was solved.
Matt
