Wireless
6948 Discussions
Miracast support in Windows 10 Laptop
I am using a Intel Core i5 laptop with windows 10 running on it. When I try to connect my laptop with my TV wirelessly using Miracast, the connection is unsuccessful and casting is getting failed. Any separate driver has to be installed ? Ideally this feature should work seamlessly as Microsoft provides option to add wireless display.
However, on the flip side, When I try to use the laptop as a Miracast Sink and my Android phone as a Miracast Source, I could able to share the phone's screen seamlessly thought there is significant delay and frame drops which is a different story all together.
Can you please help me understand why its not working in earlier case when I try to use the laptop as Miracast Source and TV as Miracast Sink ?
P.S: Network Adapter: Intel Dual Band Wireless AC7265,
Driver Details: Netwbw02.sys, file version 17.15.0.5
DxDiag output - Miracast: Supported
Video Driver - WDDM 1.33
WiFi NDIS - 6.4
Suriya.
Hello suriyamohan,
Thank you for joining this Intel Community.
This standard is natively supported in Windows® 10.
You can find instructions for using Miracast*, including system requirements, at the https://support.microsoft.com/en-us/search?query=miracast Microsoft* support site.
This article may be helpful, too:
Wanner G.
Under Contract to Intel Corporation
Dear Wanner,
Thanks for the response. I have already gone through the links. Its not useful to debug the actual problem.
Later yesterday, I could use 2 windows laptops, one as Miracast Source and another as Miracast Sink. But both the laptops did not work as source and connect with my TV.
Is there is any tool or mechanism to figure out the exact root cause of the connection failure ?
Suriya.
Hello suriyamohan,
Unfortunately, there is not a tool that we can provide.
If you need assistance with Miracast*, please contact Microsoft* and your system manufacturer for support.Wanner G.
Under Contract to Intel Corporationhttps://support.microsoft.com/en-au/contactus/
