Wireless
8782 Discussions
My Wireless Drivers "Intel (Registered) Wireless AC-9650" is not started
Peterlol295
Dear the great Moderators,
I am here to know how to fix the driver named : Intel(R) Wireless AC-9650 is not started when I playing some games like: Roblox, Fortnite,... But It's not started anyway. Sometimes, I opened the devmgmt.msc on my PC, but it is got a Warning Icon next to it. I use every way (From Simple To Advanced) to fix it. But it occurs every day (I did the Issue Solutions the someone's got a same Error (This is From MookyIntel Wireless AC-9650 Won't Start - Error Code 10 - Intel Community)
I hope all Moderators have to know it. Anyway. My PC information: ASUS TUF GAMING FX504G D-E4571T Use NVIDIA GeForce GTX 1050 and Intel Core i5 8th Gen including Intel Wireless AC 1050.
I wanted all moderators to fix this issue
Yours faithfully
Peter
PS: Tags: #Wireless #Intel #9650 #PeterJosephson The Picture down there is a proff
David_G_Intel
Hello
Thank you for posting on the Intel️® communities. Please share more information with us:
  • Do you also get Bluetooth issues?
  • When did it start to happen?
  • Do you remember if this issue happened after a new OS update or Wireless driver update?
  • Is this a new computer? If so, have check with your system's OEM for validated drivers or support on known issues related to the symptoms experienced?
  • What OS version are you using?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • Were you able to have you wireless connection in a normal/expected performance before?
  • Have you installed any recent software or hardware in your system?
  • Have tried a roll back to a previous driver version for testing?
  • Did you test different drivers?
  • Provide the Intel® System Support Utility (Intel® SSU) results
    • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
    • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
    • Click on the menu where it says "Summary" to change to "Detailed View".
    • To save your scan, click on "Next", then "Save".
David G
Peterlol295
PS on the topic: Intel SSU Information under this description (This is my second description)
David_G_Intel
Thank you for the information provided. As a friendly reminder, please answer the previous questions to provide the most accurate troubleshooting steps. From the report provided we noticed that you're not using the latest Windows 10* and the latest driver. Please update Windows and then use the latest OEM driver available on their website:
David G
David_G_Intel
David G.
David_G_Intel
David G.
David_G_Intel
Before we close the case, please remember that if you followed the steps and the issue persists, the best is to verify the behavior with the manufacturer.
David G.
